Newegg has stock of AMD's budget 65nm X2 3600+, but you'll need to buy it in a bundle with a Biostar mobo.
It would seem like progress with AMD's 65 nanometre manufacturing is going well, because the company has quietly introduced a Brisbane-based Athlon 64 X2 3600+.
Things are a bit more complex than that though, because the processor is not listed on AMD's
official price list; instead, Newegg has started stocking
an OEM version of the processor.
The new chip comes with a 1.9GHz core clock (with a 9.5x multiplier) and 2x512KB of L2 cache. Newegg is stocking the processor for $115 USD, which makes for a very attractive price.
However, the online retailer states that the chip must be bought as part of a CPU / motherboard combo that will set you back $168.99. The motherboard included in the bundle is Biostar's TForce 550 motherboard (nForce 550) - at that sort of price, you can't really expect very much from the board.
The specifications differ from the original X2 3600+, which was said to be an OEM-only release in
the second half of last year. The original Athlon 64 X2 3600+ was manufactured on AMD's 90 nanometre SOI process and came clocked at 2.0GHz. Instead of reducing the clock speeds, AMD opted to dock the L2 cache - the X2 3600+ only had 256KB of L2 cache per core back then.
It'll be interesting to see how this Brisbane performs, because the
65 nanometre X2 5000+ EE was slower than the 90 nanometre Windsor based X2 5000+ it will eventually replace. There shouldn't be much competition for the X2 3600+ though, because Intel's cheapest Core 2 products are priced well above $150 at the moment. The only real contender that it has to deal with is Intel's Pentium D 915, which Newegg sells
at exactly the same price as AMD's budget dual-core processor. We wonder how long it'll be before you'll be able to buy X2 3600+ on its own.
Thanks to
The Tech Report for the tip.
8 Comments
Discuss in the forums ReplyI would do it if I had a matx option..
I also much prefer nVidia, yet ATI are owned by AMD. I am straaaange.
They are also selling them over here, and you don't have to get it with a bundle either.
But the price difference between the 3600 X2 and the 3800 X2 are negligible, $20NZD or 8 quid.
i happy AMD have made this chip as thay did not have an low end dual core cpu to compeat with the 805 or 9xx chips before (Price wise NOT performace wise, amd chips are faster then the 8xx and 9xx just the price was not there)
give me an option to make an dual core cpu now as i working up vista ready pcs (uk prices i think be 70- 80 ish)
