Vista will be more enthusiast friendly than we thought.
Microsoft today talked to
bit-tech in a bid to reassure the enthusiast community about the licensing terms of Windows Vista.
We
previously read that Vista could prove to be a nightmare for enthusiasts who upgrade often, with only one transfer to a new machine allowed and with the license tied to a particular system configuration in a way that was far more limiting than Windows XP.
A Microsoft spokesman from the Licensing Dept told
bit-tech that this would not be the case. He told us that Windows Vista will not require a system re-activation unless the hard drive and one other component is changed. This means that enthusiasts will be able to swap CPUs, memory and graphics cards out without any worry about having to re-activate with MS, either on the internet or by phone.
Should you change the hard drive and another piece of hardware - for example for a major upgrade such as a motherboard change that requires a re-installation - Microsoft will allow you to re-activate up to 10 times. You will not, however, be able to have more than one machine activated concurrently.
Should you wish to activate more than 10 times, you could be busted, or Microsoft could choose to let you activate again at its discretion.
For hardcore system enthusiasts, keeping a ghosted, activated copy of Vista with no drivers could be a good way of being able to swap around components and machines with the minimum amount of hassle.
This would seem to clear up some of the confusion about Vista activation. Let us know what you will be doing over in the forums!
I'm glad I'm not the only one that kept the format every 3 months or so habit ;)
This is better than was previously mentioned obviously, 10 times will be enough for most of us upgraders. My XP has probably been through maybe 7 major changes.
Not perfect but better would be my feeling
Going by the article, re-Installing just to keep the system clean shouldn't be a problem.
Are you really going to change those components more then 10 times?
3 new hard drives (2 of which were C:)
about 5 new opticals
2 new motherboards
3 new graphics cards
Ram, changed twice
PSU (The old one set on fire)
Sound card.
I'm not sure if I have changed processor... I may have... not 100%...
(I still have my original NIC. rarr!)
Now I'm rather glad I use 2k rather then XP because I've had to do precicely zip in order to change all that hardware other then change the drivers over, and physically install it.
I personally can't see me migrating to Vista any time soon as it looks more limiting then XP with no upside, (higher hardware requirements with no added functionality) which looks pretty weak compared to 2k tbh.
Can't help but think that microsoft should be forced to buy back the licence after the 10 instances get used up.
If microsoft no longer want their custom then they should at least pay back the money the consumer payed for its software.
So you don't need to active when you do a fresh install? Wow, who knew that M$ could keep your activation data on the HD, even surviving a format.
Upgrading a video card, will not require activation, nor will ram, cpu, soundcard, etc. Those things don't require reinstallation either.
Unfortunately, from the limited information given above (and drawing parallels with XP's activation scheme) it's entirely possible (and I would say likely) that Vista will require activation upon installation. That could then count towards your total of "10".
The only thing I could see that *might* let you get around this, is the ability to backup your activation info before you format/reinstall, and then import it back into the system. Do we know if Vista will support something like that?
I think it's still a good idea to be critical. The EULA definitely did not say what the M$ rep is reporting, so this "change" is in direct response to all our compliants, which is good. We have to stay vocal, to keep Microsoft honest.
Aggies
Easy enough, just takes time.
to computer sys admin : i doubt the enterprise version etc that you will be deploying over your networks will have this issue so it wont really matter to you
to bit-tech geek people that build fun systems to test : you could get the afore mentioned enterprise one to allow this.
to people that build new computers every week : if you buy a broom , then change its handle, and a week later change its brush, it is _NOT_ the same broom, ergo, if you change your hard drive, and your motherboard, ZOMG! its _NOT_ the same PC -- you could quite easily have just built it and tried to install windows on it keeping your old one up and running at the same time. Stop flaming MS for just trying to sell a product, after all thats ALL it is, all politics about MS asside, its a company, it has to make money, and to be fair, its being rather nice about it, it could set it to 1 as .. it IS there software.
An MS apologist? Here??!
I regard myself as buying some software. Microsoft regard it as me loaning some software for a fee. OK, I can accept that, I suppose. But MS say that I can only use it on one PC - ever.
Hang on! Even the scum-sucking pigs at EA dont try that kind of trick. They at least allow me to re-install their software on a new PC. And again on a new PC after that.
When I hire a chainsaw I dont need to nominate which bit of tree or hitchhiker I'm going to cut up. When I hire a car, I'm not limited to driving it on the A1; I can drive it wherever I want. If I buy a DVD from Disney (er.. for example), I'm not obliged to only watch it on the one DVD player. I'm not allowed to copy it, but I can play it where the hell I want to. If I buy some fluffy dice for my car, I can change cars or even put it in my wife's car.
Yes, Microsoft is there to make money, but it has a responsibility not to exploit its customer base with draconian licensing clauses.
CJM
To fit a burglar alarm doesn't imply you're treating everybody as criminals, it's a logical precaution because so many people are bent. Blame the bent people, not the people who fit alarms.
Every re-format changes the VSN (though you can change it back) and wipes the local activation files, which might be why MS say "the HDD and any other component" would come into the total permitted, whereas HDD reformat only wouldn't. Seems logical, even better than current, providing the checker is reset every few months so I can upgrade HDD in January and something else in April without a hiccup. :?
And herein is the crux of the matter. You are correct and wrong at the same time.
You did purchase it from them. And it is yours. And always will be.
The problem is it is not the software; it is the use of the software under the conditions laid out in the EULA.
I'm pleased that MS are saying that by and large we won't be affected, but the real issue is that they *could* shaft you at any time. They decide if/when you are able to re-activate.
They would never do it, Microsoft has had the power to ID every single Illegal copy of XP that was ever connected to the internet, the reason they dont do it, is because it would destroy them, and its probably illegal.
If this Hard disk + one other is true, does that means you could change everything except the hard disk and be ok? or you could change the Harddisk and nothing else.
Re-installing vista after change some items i doubt would count to the 10 activations, as long as it wasnt the Hard disk + 1. I suspect that Hardware IDs would be used to create some kind of number, that number would be used apon activation and if it showed that the things have not changed outwith there harddisk plus one it wouldnt count to there 10.
What if at 10 your HD dies?
Perhaps activation works kinda like Steam? I mean, perhaps the activation info is stored online and Windows periodically checks with such info. If your hardware differs significantly (different HD and different somethingelse), it prompts you to reactivate...
Of course I have no clue... but such a method could work, right?
The EULA can say that I'm giving my immortal soul to MS by installing Windows, or that I have to give them my first born male.
I don't know about the USA, but in European continental law, there's a concept called "Abusive Clause" . More or less, it says that some clauses included in contracts are so abusive towards the consumer that it's irrelevant if he agrees or not when signing them...they are simply invalid.
The software EULAS are a great example of "Abusive clauses". More so, when they come from what effectively is a monopoly ( don't tell me there are alternatives...the EU and USA administrations have already make quite clear that for all intents and purposes, MS sports a quasi-monopoly in the personal OS market). They haven't yet been tested on court, but I have no doubt that, at least in Europe and with the focus on the consumer the EU Commission is sporting lately, the first time they are tested against the law will be the last, as they'll be rendered void of any strength.
So, MS can say you are limited to 10, 2 or 200 upgrades for all I care. I'll get my legitimate copy of Vista. I'll upgrade as much or as little as I fancy. If I ever have any problem reactivating, I'll call to MS Spanish Support and I bet they'll allow me to reactivate with little problem... and if they don't, I'll get a crack. And if the crack is unpractical (because of things like WGA), I'll go to the OCU (Consumers and Users Organization...it's awesome how effective this guys are against big corporations), make a formal complaint and I'll get a new license faster than you can say "take that suckers".
Really people, those living en Europe have loads of EU and local government supported tools and bodies at their disposal...and for the most part, they work pretty well. Just give it a try if MS, Apple or SONY want to shove and excess of trash through your throats ;)
[edit]
BTW, I'm assuming all this discussion is regarding the normal, retail version...if we are talking about OEM versions, things could be slightly different, as after all, you are getting a cheaper version with reduced functionality.
If that's the case, 10 upgrades isn't that bad... with OEM XP, in theory, any motherboard upgrade rendered your license invalid, and the fact is that I haven't heard of anybody whose XP couldn't be reactivated after a MB change
[/edit]
Following applies to XP
The answer that was given at the presentation when the subject of reactivation came up was; "For the Retail version of Windows Vista you can transfer the OS one time. After that you will need to purchase a new OS."
So were the people behind the presentation were not updated? Or was the Microsoft representative that stated you could re-activate up to 10 times misinformed?
I'm with MS on this. They have a company to run, and this stops people from abusing their software by installing it on more than one PC at a time. Companies have been doing this through different methods for ages now. How many times have you gone to play a game and been told to insert the disk before you can play it? Did you complain? No. So would you rather have to insert a Vista CD every time you switched on your PC? Didn't think so. To be frank with you, this is probably the best way of doing it. Do you have a better way that _won't_ make Microsoft, the consumer or anyone else lose out? If you do, I'd sure like to hear it.
_C
(had 3.1, 3.11, 95, 95b, 95 w/USB support, 98, 98se, Me, 2000 and XP)
Regards
GiGo
For people mentioning how much RAM it uses and how its a huge hogg blar blar, i would recomend that they give it a go, because whilst it does "take" more RAM the way it uses it, the way it can free it up is a massive improvment on XP, the page file is finally being used correctly where only infrequent info is placed.
Theres a much better system inplace for stability, once the initial auto defrag is over the system is much more responsive, ive not found anything thats worse than XP yet, the new start menu is a god send, pat on the back for whoever thought that thing up.
I'll admit ive turned off the 3D stuff, why? becuase i have no use for it, it makes no difference to how most power users work, if your OS choice is on how something looks then i suggest you get a Mac, thats not to say its bad, it actually looks lovely, its just not something i give a damn about
BUT
all of the goodness in this OS will go to waste if this licence business doesnt get sorted to my liking, i spend a fortune on upgrading, in many cases i buy the fastest gear i can afford to keep the system running longer, i cant afford a new OS every other upgrade. Just dont slag off a system youve "heard" is crap thats all, becuase most of the problems i help in the beta community with are old legacy hardware related, an whos fault is that.
