MSI K8Nes new nForce 410 boards
The K8NGM2-ILD has a DVI port on the back panel. Sweet!
MSI have upgraded their motherboard line with a new range of nForce boards, which sport the K8N moniker.
Pictured is the K8NGM2-ILD. This is a Micro ATX board which is designed for home theatre PCs. It sports the nForce 430 chipset and GeForce 6100 integrated graphics, along with a DVI connector on the back panel for hooking up to a flat panel display in your living room. It also has a passively cooled north and southbridge, allowing you to keep noise to a minimum!
Also in the range is the K8NGMV-2, which is a rather similar board, but supporting Sempron on Socket 754 rather than Athlon 64 on Socket 939. Paired with the nForce 410 chipset, it also has a couple less SATA ports.
Rounding out the new range is the updated K8N Diamond board, which now is equipped with a pair of x16 PCI Express slots for the fastest SLI performance possible. It also has dual gigabit LAN and Soundblaster audio onboard.
All in all, a strong showing of new products from MSI - you can bet that we'll be kicking them through our test platforms as soon as we can mount a raid on the MSI warehouse.
Like the look of these babies? Tell us in the News Discussion forum.
