The WiFi Camera uses a series of antennas to build a picture of the world in shades of 2.4GHz - no light required.
A clever camera constructed from WiFi antennas and some custom circuitry is capable of taking snapshots in the 2.4GHz spectrum.
The
WiFi Camera - via
Make - is the work of Bengt Sjölén, Adam Somlai Fischer, and Usman Haque and is designed to perform the same function as a traditional camera: the taking of images - and, the group claims, soon video as well. However, this camera - as the name suggests - doesn't capture light, but instead takes a peak beyond the visible spectrum into realm of radio waves.
The camera is based around the principle that "
radio waves at WiFi's wavelength behave similar to light in that they are reflected off almost all solid objects to varying degrees," meaning that - just like light - it creates a vista, being bounced around, diffracted, and diffused invisibly around us. By strapping a series of WiFi antennas to some custom signal analysis equipment, the WiFi Camera turns the invisible visible: capturing an image of how the view looks in the 2.4GHz spectrum.
While the initial version of the camera was limited to valid WiFi signals only, the team behind it have upgraded the signal analysis equipment and can now capture
any 2.4GHz signal - including from mobile 'phones, microwaves, and DECT devices.
While the device is currently nothing more than a curiosity, the technology behind it could have an impact on how we analyse the propogation of wireless signals - and how WiFi signal strength and quality could be improved in the future.
Are you impressed to see photographers looking beyond the visible spectrum for inspiration, or is the WiFi Camera nothing more than an expensive kaleidoscope? Share your thoughts over in
the forums.
17 Comments
Discuss in the forums Replyhttp://wificamera.propositions.org.uk/visualization
Great concept, but ultimately, a little disappointing as an artform. let's hope that it finds more uses in tech!
You don't think they would have turned that off?
And from the pictures, it appears each antenna was 'viewing' data from different WiFi access points, so I imagine the only interference from the laptop would be when it was showing the specific frequency that the laptop was communicating at (which could be avoided).
neither is light. It is scattered about and travels in straight directions. it is not suspended in air.
they are all waves.
that is why there are directional antennas. because radio waves can be concentrated towards a point, just like light can.
