The PrePeat printer allows images to be printed up to 1,000 on each sheet of PET-based 'paper.'
If you have a tendency to print out a lot of information which you only need temporarily, the PrePeat printer might be just what you need.
As reported over on
Engadget, the PrePeat from Sanwa Newtec uses PET plastic sheets rather than traditional paper, on to which a temporary image can be transferred by the application of heat - in black only for now. Once you're done with your printout, simply feed it back into the printer and it'll erase the image and replace it with a new one.
Unlike a traditional printer, the PrePeat doesn't require toner or ink, and the individual sheets are reusable up to 1,000 times before they refuse to take an image. While still in the early stages, the technology holds promise for offices where lots of printouts are required for meetings only for the paper to end up in the shredder in short order.
This isn't the first time somebody has thought of the idea of reusable paper: Harry Harrison and Marvin Minsky came up with the idea of an Eternitree printer which worked along the same principles back in 1992 in their collaborative speculative fiction work
The Turing Option. However, the PrePeat is the first commercially available printer to work along the principle of reusable 'paper.'
Interestingly, the plastic nature of the sheets used in the PrePeat printer mean they are naturally waterproof - meaning that the issue of safely reading e-books in the bath might have finally been resolved.
Sadly for anyone hoping to get their hands on a PrePeat, the early models aren't exactly cheap: the printer itself will set you back around ¥500,000 (£3,584) and each sheet will cost ¥300 (£2.15) in units of 1,000 - meaning an initial outlay of ¥800,000 (£5,734) to get you started. Despite this, the low cost-per-page and high durability of the printouts - so long as you keep them away from sources of heat - may make the PrePeat a winner with corporate customers.
A video of the unit in action, made by DigInfo.tv, can be found on
YouTube.
Can you see a use for temporary printouts, or does the cost need to come down before you'd be interested? Share your thoughts over in
the forums.
11 Comments
Discuss in the forums ReplyI wonder how thick each sheet of this "paper" will be? I think that the thickness (and the weight) will affect the use of this by corporations in the future. Color would be a nice step in the future as well, but I don't see how they will manage to do anything other than black and white (with maybe some shades between).
Also, I hope you don't take baths that are too hot, otherwise you might be erasing your pages while you soak in the tub.
Not if the bath is really hot though :p
What if the reader is hot?
I mean if you are HOT with clothes on then this will just get erased as soon as it sees you in the nude!!!
Erm... I'll get my coat...
If its plastic, just use Dry Erase markers. Besides don't most people in corporate environments note-take on Netbooks/Notebooks/PDA's/insert-gadget-here ?
You'd be amazed at the amount of paper still used.
Ask a beancounter to provide engineering staff with 300$ netbook/100$ PDA each or with a 5ct pencil and let them type it out afterwards?
Typing out costs time, an engineer costs 100$ an hour so it'll repay for itself in...hmmm...we...let's go with the pencils!:D
