Fujitsu unveils rugged RFID
The new, flexible RFID from Fujitsu can work even when subjected to two atmospheres of pressure or 120 degree heat.
Despite growing concerns over the security of the technology, RFID use is growing exponentially - and a new development by Fujitsu could see the chips embedded even deeper.
The new ultra high frequency RFID tags are described by the company in a CNet article as being able withstand temperatures of 121 degrees Celsius - significantly above the boiling point of water, and well above the temperature at which traditional devices will stop working. The new tag is also flexible, meaning that it will survive rough handling much better than older RFID systems - and can deform safely under pressures reaching two atmospheres.
The reason for all the robustness built in to the tag is simple: Fujitsu is hoping to see the devices used in the medical industry. While RFID tags are often used to track batches of uniforms around a garment factory, their delicacy often means that once they reach the hospital or medical equipment manufacturing plant and are washed at a high temperature - required to ensure that no nasty germs breed on the uniform's surface - the tags are rendered useless. The new robust tags should, however, withstand repeated washings - even at boiling temperatures - and allow the automatic tracking of the uniforms using an RFID reader system.
Fujitsu claims that the use of the new tags could mean that batches of 100 uniforms could be scanned simultaneously both before and after being washed at high temperature, which could result in impressive efficiency gains when it comes to ensuring that workers get their clothes back in good time.
The possibility for the technology to be used to track workers rather than just uniforms remains, of course, unsaid.
Do you believe that RFID technology is the future, or should we be more concerned at the idea of a uniquely identifiable code which can be read invisibly and silently at a distance being attached to our clothes? Share your thoughts over in the forums.
9 Comments
Dave Lister 8th October 2009, 16:02 Quote
Great another way to be tracked !
Cruelinios 8th October 2009, 16:12 Quote
not necessarily, RFID works over extremely short distances. I can see the benefit medically, scanning a body area to reveal medical conditions etc and for other similar situations it will be useful, but in secure models RFID's encryption has already been cracked, so hopefully this can be applied to the 'next generation' of RFID.
thehippoz 8th October 2009, 17:07 Quote
better not borrow your bosses pants
TWeaK 8th October 2009, 21:21 Quote
Wouldn't it be nice if the article included a paragraph or sentence explaining exactly what RFID is? I know Google/Wiki can tell me but I like my information summarised in one place.
jake9891 8th October 2009, 22:36 Quote
i agree with TWeaK, I had to look on wikipedia what exactly RFID stands for. Just to give other people idea, it stands for Radio-frequency identification, for more go to wiki or google ;)
@thehippoz: I LOLed ;)
fodder 8th October 2009, 22:48 Quote
Oh great, no more free scrubs for doing the decorating in from my nurse friends :-(
B3CK 8th October 2009, 23:07 Quote
So could I use this to tag my dishes, so that I finally build a robot to clean and put up my dishes? I bet I could get the wife to go for that.
Or tag my socks so I don't end up wearing a sports sock, and a normal sock at the same time?
Or tag all my clothes so I don't have to waste time picking out what to wear, just have a preset option of outfits. (Colorblind, and a techie leaves my wardrobe messed up most days).
Star*Dagger 9th October 2009, 04:24 Quote
TWeak, if you can not open a new tab and type in RFID into the search bar you have larger issues, lol.
As far as the tech fine, the EU will limit abuses, though I am sure the US will abuse the hell out of it until someone sues for 40 billion dollars (which by that time will be enough to buy a doner kebap in Germany)
Yours in Tracking Kebaps Plasma,
Star*Dagger
MonkeyTurnip 9th October 2009, 22:50 Quote
personally i can see the benifits from this, not just to track clothes but one step closer to checkout-less supermarkets etc, making RFID more ruggged is the future. for the tin hattists of you you can be tracked by your phone, credit/debit card use etc.
