MS warns over unpatched IIS flaw
The security flaw in IIS is being actively exploited, but thus far there is no patch for the issue from Microsoft.
Microsoft has issued a warning that an unpatched flaw in its Internet Information Services web server software is being actively exploited by crackers.
According to an article over on InfoWorld, the company has seen a rise in the number of attacks targetting this latest IIS vulnerability since the flaw was made public last week.
The bug - which affects IIS 5.0, 5.1, 6.0, and 7.0 - can trigger different effects depending on which version you are running: older servers relying on IIS 5 and Windows 2000 are at the highest risk, with a successful attack resulting in remote code execution providing the attacker is able to create a new directory via FTP; newer IIS versions on Windows XP and Windows Server 2003, however, simply suffer from a denial of service crash if the attacker is able to read files via FTP.
Microsoft's security advisory for the flaw states that the issue is currently under investigation as part of the "Microsoft Active Protections Program," and that "upon completion of this investigation, Microsoft will take the appropriate action to help protect our customers."
This action may result in an out-of-cycle update for the software: while Microsoft prefers to stick to its Patch Tuesday release schedule for security updates, the scope of this flaw and the fact it is already being actively exploited in the wild may well tip the company's hand into releasing the fix early.
In the mean time, workarounds to prevent exploitation of the bug include disabling IIS - not really an option for business users who host their website via the software - or preventing access to the FTP service except via trusted addresses.
Should Microsoft be issuing a patch as soon as possible to fix this flaw, or can it afford to wait for thorough testing - even though ne'er-do-wells are using the hole already? Share your thoughts over in the forums.
6 Comments
thehippoz 9th September 2009, 15:47 Quote
I like how they say it was not responsibly disclosed
Flibblebot 9th September 2009, 16:16 Quote
It just shows the problem inherent in only releasing patches once a month: it gives the script kiddies up to a month to wreak their havoc. I know it makes sense from MS's point of view - it gives them a month to test new patches - but from a customer's perspective, it sucks sweaty monkey balls.
That said, are many companies going to be running IIS with FTP enabled, let alone open it to all and sundry?
kosch 9th September 2009, 16:24 Quote
Another reason why I dont use IIS for FTP Servers in our farm. :)
Otto69 9th September 2009, 18:46 Quote
IIS == Inherently Invade able Software?
LordPyrinc 10th September 2009, 01:58 Quote
Rushing patches out the door without sufficient testing time is just as dangerous as that might break other functionality or introduce new problems of their own. I also know from my experiences as a software developer that sometimes you go into fix a problem and uncover other flaws downstream from that fix that need attention as well.
Shagbag 10th September 2009, 08:48 Quote
While Apache is not without bugs, at least they're fixed a lot faster than it takes Microsoft "time to test and develop a patch".
FFS Microsoft, does it really take you a whole month to fix broken code? I can't believe your developers cannot read C++, so it must be your leviathon management structure that slows things down.
