Sign up to the folding team today and help cure diseases caused by misfolding proteins.
The newly combined
Custom PC & bit-tech folding team has been doing very well recently, holding on to its coveted fifth place among the world's top folding teams. However, team 35947 needs your help now more than ever.
Earlier this year we were invited to take part in the annual
Chimp Challenge to see which team can produce 20 million points in the shortest time. Although Overclock.net and several other teams have already met this target, the fight is not yet over.
To avoid the embarrassment of coming last and to make sure team [H]ardape from
HardOCP gets the dubious honour of the 'Monkey's Paw' we need to increase our folding production by around 500,000ppd, less than 1/4 of our team's usual total output.
To sign up your CPUs, GPUs and PS3s to the cause make sure to enter 'CPChimps' in the username field of your folding clients with the usual team number '35947'. Once the last of the competing teams has reached 20 million points you can reset your folding clients back to your usual folding usernames.
Don't forget to say hello in the all-new dedicated
folding forum too!
Discuss
in the forums.
http://img188.imageshack.us/img188/5871/fah1.jpg
I'm not for a moment suggesting its a bad cause at all, i just wanna know if its the sort of thing that needs a long time to cure one disease or if it just provides a load of data or what, just curious :D
good luck! it is a worthy cause!
http://folding.typepad.com/news/2008/12/new-fah-results-on-possible-new-alzheimers-drug-presented.html
@ForumNameHere - the CPU clients and GPU clients are separate clients, so if you've got a suitable GPU you'd need to install the 'high performance' GPU client.
and where is the gpu client, Captain noob over here couldnt find it, so if anyone can help that would be great, lets get folding
peace
fatman
It be here:
http://folding.stanford.edu/English/DownloadWinOther
It's referred to as the High Performance Beta client, hidden away at the bottom of the main client download page. Happy folding!
Also, if it's set up on one box, can you just move the folder to another and run it? (could have 20 8 core machines helping out)
Use the VMWARE guide in the folding forum
A conservative estimate based on total number of GPUs assigned to the project would suggest about 10,000 other people are doing it. The only thing you've got to worry about is the heat output into your room. These cards are easily capable of sustaining full load for (at least) months at a time.
Well, what would it take to convince you otherwise. I guess the 60-or-so peer-reviewed scientific papers (which incidentally is far more than any other DC project) produced from the results wouldn't? It's also telling that the default team (which is set if you don't change any settings) has submitted more data to the project than the top 8 teams combined.
If you can run the Macs in OS X you can install the native SMP client which will be faster than VMWare and has the bonus of you not needing to use Windows :p As far as moving the folders around, yes-and-no, it depends which client you installed, and how.
If it only uses the GPU can a second client be run to also utilise the CPU?
Or am i best leaving it as it is?
As I'm running a dual core I guess I'll download the standard single core client and run both then :)
You'll need to download another GPU client for your 8800 GTS. As setting up additional clients is pretty complicated, I'd suggest picking up the latest issue of the mag which has a 17 page guide or heading over to the folding forum.
This is unlikely I'm afraid, there are a number of fundamental differences between the two architectures which can't easily be resolved. It was attempted a few years back, and failed.
I need to read 17 pages in order just to change which card F@H runs on ?!!!!
I see, hmm tried playing with that before, made no difference what so ever.
And I gave up with trying to run multiple instances yonks ago.
Oh well screw it, ive already part of the team from years back, and have a bunch of machines at work where ive installed it as a service (much to my boss's dislike) since way back, that do run 24/7.
