Several HP printers - all business-oriented models with in-built networking - are vulnerable to an information disclosure attack.
You might be sure that your PC is locked down against attacking crackers, but how often do you update your printer's firmware? If you're a user of HP devices, the answer may well be “not often enough.”
According to an
article by The Register's John Leyden yesterday, HP is warning customers that certain models of laser printers are vulnerable to a remote exploit which can allow access to the internal settings – including the ability to view and download copies of previously printed files. While the vulnerability isn't likely to result in an opening for further attacks against an internal network, the privacy implications push the severity up a notch.
The affected models – all network capable – are the HP LaserJet 2410, 2420, 2430, 4250, 4350, 9040, and 9050; the HP Color [sic] LaserJet 4730MFP, and 9500MFP; and the HP 9200C Digital Sender. If you – or, more realistically, your company – uses any of these models it would be a good idea to snag an
updated firmware which addresses the issue.
The vulnerability – assigned the ID CVE-2008-4419 in the
Common Vulnerabilities and Exposures project is thought to be mitigated by standard border protections, but still represents a potentially troublesome security hole – made worse by the fact that most security audits gloss over embedded systems such as printers.
HP has declined to comment on the issue, apart from warning customers that the patch information available as part of its security bulletin should “
be acted upon as soon as possible” by customers with affected devices.
Rushing to patch your personal printer before the crackers get their hands on your printouts, or are you hoping to get a sneak peek at what the CEO's been printing out of office hours? Share your thoughts over in
the forums.
15 Comments
Discuss in the forums Replyedit: oh you need to use IE.... perhaps b-t's new corporate overlords have something to do with this? :P
http://www.wsgfmedia.com/paradigm/images/screenshots/intellitxt-fail.jpg
Forgive the JPEG artefacts.
More Blackberry ads. Neat. Apparently Blackberries are useful for "operating systems" and "internal networks"...
Anyway, the issue is a nasty one, good that HP fixed it. :)
Dennis have to make money out of Bit Tech somehow..
I run firefox, and haven't even installed Adblock yet. I still don't get them.
Stage 1 - someone buys some webspace and mounts a forum on it. His friends join.
Stage 2 - site becomes successful enough to employ people
Stage 3 - site is purchased by a large media conglomerate, and users find sport in writing utilities to compare linguistic distribution of site's articles to that of current Sony, Nintendo and Microsoft press releases.
Not to worry, though - it's a rolling process, and by the time bit-tech has finished becoming a waste of space, there'll be someone else around doing the job they used to do so well, and who aren't afraid to have a link to the LED resistor calculator on the front page.
P
As tank_rider wrote - good printer should have some tool to clean up the disks after printing
