No HDCP? No problem.
Those of you familiar with DVD copying...err, authoring tools will no doubt be familiar with the company Slysoft. Its
AnyDVD and
CloneDVD tools are two of the most popular protection/preview stripping programs around. Well, with all of the HDCP Vista issues, you'll probably be happy to know that Slysoft is at it again -
AnyDVD HD will strip the protection off of HD content, allowing it to play to non-HDCP monitors and TVs.
Currently, the technology works only for HD-DVD (Blu-Ray is not supported
yet), but the implications are vast. The project basically nullifies the HDCP requirements that Microsoft was forced to put into Windows Vista, meaning that its usefulness as an HTPC is dramatically increased. On top of that, the program can decrypt the files for hard-drive storage.
Slysoft argues that piracy is of relatively little concern for the HD world. HD movies require 30Gb to transfer, which is a pretty massive download. In order to then burn the disc, a person would also need an HD-DVD drive and blank discs, which don't come cheap. Effectively, the cost of mass piracy far outweighs the cost of simply buying the discs legally, so the benefits of
AnyDVD HD shouldn't cause a big dent in sales.
If you're interested, you can grab the program on
Slysoft's website for $79.99, or upgrade your current AnyDVD license for $30.
Do you have a thought on it? Tell us
in our forums.
30 Comments
Discuss in the forums ReplyIn other words, three w00t!s for Slysoft :)
What about ripping a hd-dvd and shrinking it down in a lossless format, losing all the other language soundtracks you don't want? It'd probably take up at least half the size, if not less.
If you're willing to sacrifice some video quality, you could easily pummel the size down, especially if you downscaled to SD, but what would be the point in that? I guess you might get better results re-encoding to a 700MB/1.4GB XVID file than you would with a DVD, because re-encoding from a higher quality original will reduce generation loss, but I would suggest that with anything bar the shoddiest of DVD transfers, the effect will be marginal at best.
Edit: I'll add that in the 90s very few home users would have entertained the idea of downloading a 4.5GB DVD-R image over their 56k narrowband connections. Now it's a pretty trivial overnight / couple of days download for most people with (A)DSL. I suspect this trend will continue as well, and while I double we'll see such a quantum leap in bandwidth as the 56k -> ADSL increase, neither is the difference between 4.5GB and 15/30/25/50GB (single / dual layer HDDVD / single / dual layer BR) particularly large in the grand scheme of exponentially increasing storage / bandwidth.
Does this mean that Slysoft is using the exploits found by the hackers?
Or does Slysoft have some other means of stripping the DRM?
Does this make the previous hacking efforts pointless -- as now the hackers can just figure out what Slysoft did and copy it?
IIRC, the various hacks were just to fake the encrypted keys...but stripping the DRM entirely sounds much more useful.
couldnt agree more...
There's this content industry that invents various copy-protection measures (be it DVD / HD).
The manufacturers of playback devices and software implement these. (apparently?)
Then there's Slysoft. They just ignore the cp scheme and allow the user to actually use the content she's paid for.
The content industry doesn't take counter measures?
How can this hold / be legal / work ?
are you sure? i mean... look at pirate bay and allofmp3......
P
piratebay, yes, but whatabout allofmp3....? they got sued.... didnt seems to stop them. :(
Allofmp3 does directly host content that (the RIAA claims) it is not authorised to offer for download.
In both cases, pirate bay and allofmp3 are offering users unauthorised copies of protected content. In total contrast, Slysoft (as I understand) has only made a tool which enables someone to strip the DRM from protected HD discs. If you only used it to back up your own discs to your media centre for streaming around your home, would you be doing anything wrong? Morally, I'd argue that the answer is clearly no, and in many countries (including the US - if we ignore laws precluding the circumvention of DRM, personal copies for fair use are legitimate), the legal answer is also no.
Let's take an analogy. Allofmp3 is selling copies of old skool analogue music tapes at a dodgy car boot sale. The pirate bay is an organisation that puts people in touch with other people who have copied tapes for swaps. Slysoft is just making tape recorders.
My understanding of the DCMA is quite limited, but I believe it prohibits the reverse engineering of software in order to strip out DRM. The DCMA is an enactment of the US legislature, the jurisdiction of which stops (regardless of what they may think) at American borders. As such, unless you live in a country bound by the DCMA or a similar law, you can reverse engineer software to your heart's content, as Slysoft has done. On the other hand, most countries do have laws preventing direct infringement of copyright, so setting up a pirate bay / allofmp3 type service is a lot more controversial.
If we're talking lossy compression, then of course the newer, more advanced codecs will likely produce better results than the older ones. However, to compress an HD movie lossily and maintain the HD resolution and acceptable quality, we need to face the fact that file sizes are still going to be pretty big. 50% might be realistic, I don't know, but that's still way above the 10GB mark for a 2 hour movie. You will have to compress quite aggressively, with some pretty horrendous artefacts, I suspect, to make a full HD movie (i.e. ~2 hours in 1080p), recompressed but retaining the HD res, fit on even a DL DVD.
Let's not forget that almost all HD-DVDs and most of the newer Blu-Ray discs are not encoded in MPEG-2 - they are using VC-1, which, though generally held in lower regard than H.264, is considerably more efficient than MPEG-2. As such, to retain most of the fidelity, you're not going to save a lot of space by re-encoding to H.264.
Even allowing for the fact that decent quality HD rips are still going to be on the >10GB scale, I predict mass torrenting of HD content within a couple of years. Definitely within 5 years it will be as trivial to download an HD movie as it is to download an SD movie now.
It may be that there are codecs that produce more efficient lossy encoding than what is used on HD discs, but the very nature of lossy encoding means that you will ALWAYS lose some quality if you decode the original HD content and re-encode it with your superior encoder. So unless you can get hold of the original, uncompressed, HD source (on the order of 1TB for a 1080p24 2 hour movie) you won't get a video file of equal quality to the HD disc with a smaller file size.
Imo, 'lossless' was probably the wrong word. I used it in the same context as people call .ogg 'lossless' compared to mp3. As mcclean007 mentioned, a h264 rip would keep enough integrity of the picture and sound.
Obviously, H.264 doesn't touch the sound, so the integrity of the sound is down to whether you keep the original lossless TrueHD/PCM, the original lossy 5.1, the original stereo (eugh, that's if they even still put 2-channel on the new discs) or a recode of one of the above.
I've never heard of Vorbis (I presume this is what you mean by .ogg) being called 'lossless' compared to mp3. As I see it, something either is lossless or it isn't, so the concept of 'comparatively lossless' is meaningless. You could say that Vorbis achieves transparency (where you can't tell the difference between the encoded version and the original) at a lower bit-rate than mp3 for most people and on most equipment. I guess also that some people can still tell well encoded 320kb/sec MP3 (think lame --alt-preset insane) from the original with certain source audio - my ears aren't that good - whereas they might accept q9/q10 Vorbis as transparent. I don't know. On my stereo, with my ears, q6 is perfectly transparent, as is MP3 at --alt-preset standard.
Granted, I may have exaggerated saying you could save about half the space, but do you want me quoting exact figures? I'm not disagreeing with you at all, I'm just trying to get my point across.
I think we're preaching from the same bible!
Anyway, personally I'm not bothered about the availability of pirate copies for download / purchase from my local friendly Chinese mafia. The reason I'd want to be able to rip HD discs is to archive them on my (future) media server, in their full, untained HD glory (i.e. no re-encoding). I will obviously tear out the unwanted languages, subs, features (I've never watched the extras on 99% of my discs, and I'll still have all the originals, so I'll be happy to put the disc in if I ever fancy a bit of behind the scenes action) and lesser quality audio streams (retaining the PCM/TrueHD/DD+ whichever is the best available on the disc). Terabytes of storage are getting pretty reasonable these days, so a RAID-5 server with ~3TB (mmm - 100+ HD films) will be quite affordable in a couple of years, when I plan to make this a reality - hopefully the ripper technology will be flawless and easy to use by then!
lol :D
I've just had a wiki on hd-dvd and there's a few more audio streams that are apparantly mandatory, i.e. Linear PCM, True-HD(2-ch)+, DD+, DD, DTS and MPEG Audio.
Am I reading this right?
The Maximum Data Transfer rate is 36.55 Mb/s on a HD-DVD, of which a maximum of 29.4 Mb/s is used for Video. This leaves 7.15 Mb/s used for audio which sounds fair enough.
Compare this to 10.08 Mb/s maximum bandwidth on a DVD and 9.8 Mb/s for video, this leaves 0.28 Mb/s used for audio on DVD!
This is what's confusing me into thinking that, you could have a lossless VC-1 video track with just your preferred audio stream and save shed loads of storage space, as the audio bandwidth on HD-DVD jumps way above that of DVD, which translates to me that audio takes up a crap-load more room in comparison (I.e. the 7.15 Mb/s for an hour and a half takes up a lot more room percentage-wise on a hd-dvd disc than a 0.28 Mb/s for an hour and a half movie on a dvd disc).
Please put me right :)
If you look in the wikipedia entry for Dolby Digital, you'll see that HD-DVD specifies 18 Mb/s maximum data rate for a single TrueHD stream.
