According to Adobe, Acrobat Reader could let in malware.
Just a quick news bite for those of you using Internet Explorer:
Adobe has announced a possible
exploit vulnerability that is accessed through Acrobat Reader earlier this week. The issue can cause a couple problems. First, it can cause Acrobat to crash, which will take IE with it, which is incredibly annoying. The other possibility includes your entire computer being hijacked by a botnet. You know, nothing really important.
The bug affects Adobe Acrobat and Acrobat Reader products version 7.00-7.08. Those of you who use the Fox to browse PDF files don't have to worry, though - the exploit will only function on Internet Explorer. A patch is expected from Adobe shortly.
The update will be available
here as soon as it is complete.
5 Comments
Discuss in the forums ReplyOr Opera ;)
that to.
