Lian Li launches the TR-5F Fan bus with Temperature Fan combo
December 11, 2008 | 14:29
Companies: #lian-li
11 December, 2008, Keelung, Taiwan – Lian Li Industrial Co. Ltd is introducing the new TR-5F, a fan Bus and Fan Temp gauge combo unit. The innovative device takes up one 5.25 bay, and has a full frontal LCD, with a coupled LED fan which changes color according to the RPM registered. At a glance you can see if your PC is running hot (red color), or cool (green color). The Fan is transparent, and has airflow of 53CFM at full speed (1500RPM).
The TR-5 allows up to four different temperatures (0ºC to 99ºC ~ +/-2ºC) and fan speeds, ranging from (1) CPU, (2) VGA, and (3 & 4) system 1 & system 2 fans, the TR-5 is more than adequate for your cooling needs. In addition the device has an Alarm for high temperatures and fan failure as well as a Date and Time function, with settings for either ºC or ºF temperature display modes at the touch of a button. The addition of the Color LED fan adds convenience to an already versatile unit.
For more details on features for the TR-5F please go to the Lian Li website:
www.Lian-Li.com/v2/en/product/product06.php?pr_index=280&cl_index=2&sc_index=33&ss_index=81
About Lian Li
Lian Li Industrial Co. Ltd is an Aluminum Chassis and Chassis peripheral manufacturer and provider of industrial wholesale as well as OEM & ODM services for the PC industry as required. With over 20 years of service excellence, ISO 9001 certification and a team of professional staff willing to do the utmost to deliver durable, superior quality products, all backed by a *2 year guarantee; your satisfaction is guaranteed.(*conditions apply)
Note to editors: "Lian Li" is spelled without hyphen as in Lian Li Industrial Co. Ltd.
Only the website URL uses the hyphen www.Lian-Li.com
Availability: Available on order now
Manufacturers Suggested Retail Price: USD55+VAT
Your local distributor: lian-li.com/where
