This press release is written by a third party and the content does not reflect the opinion of bit-tech's editorial team
Notebooks’ HDD and CPU have to resist high heat. But cooling performance of integrated cooling fans does not suffice for high working load and high environmental temperature. Enermax’ notebook cooling pad Aeolus finds a remedy for this problem.
Hamburg, 3rd December 2008. Even at usual working load many notebook cooling fans are running in full speed. Their cooling performance is often too low to protect essential components like CPU, HDD or battery against heat accumulation. Everyone, who once worked with notebook on his knees, knows that notebook bottom side becomes really hot. Accumulated heat reduces system component’s lifetime. An additional notebook cooling pad could work wonders.
Comfortable silent, broad cooling area
Enermax gained long lasting experience in developing PC and PSU cooling systems, which are widely known for their high efficiency and ultra silent operation. Notebook cooling pad Aeolus combines all of these advantages. Most cooling pads are equipped with three or more small cooling fans. Enermax Aeolus in contrast provides one 25 cm monster cooling fan under an air-permeable surface.
Its advantage: The bottom side of notebook gets a constant and broad-area cooling. Furthermore rotation speed of Aeolus cooling fan can be adjusted manually. Already at 650 RPM CPU temperature decrease reaches 20°C. And even at highest speed up to 850 RPM Aeolus cooling fan operates comfortable silent with about 20 dB(A).
Eye-catching Design
Notebooks are not only practical companions during business trips, but due to its often exceptional design also exclusive eye-catchers. Ordinary plastic cooling pads could destroy noble impression. Enermax put a lot of effort in developing a product, which matches highest demands in design and quality. Aeolus comes up with a high-class and robust brushed aluminium case. The switchable blue LED lightning of cooling fan completes cool and timeless appearance.
Notebooks up to 17" wide screen fit with Aeolus (dimensions: D 295 x W 330 x H 45.5 mm). USB power supply supports portability of Aeolus.
