This press release is written by a third party and the content does not reflect the opinion of bit-tech's editorial team
Hamburg, 14 November 2008: The Japanese Scythe Co., Ltd. (Tokyo, Japan) is known for its functional solutions - with the Kama Panel 3.5", the cooling specialist presents a new product, which combines a multi-card reader with a 2-channel fan controller and the ability to connect S-ATA, USB and audio directly to the panel.
The integrated card reader supports all common storage media - whether SD / SDHC, Compact Flash or Memory Stick *: Simply insert the memory card and read it out!
The integrated fan controller allows an independent regulation of two fans over two control wheels with stylish blue LED illumination. For connecting the fans, 3-pin cables are included.
The Kama Panel 3.5" simplifies the annoying switching of headphone to speakers at the rear of the chassis. The audio ports for headphones and microphone can be connected directly with the front panel using the Kama Panel 3.5". In addition, it is possible to use one motherboard USB and one S-ATA port directly on the front.
The Kama Panel 3.5 "is now available for an MSRP of 21.00 Euro / US$ 27.00 excluding VAT.
Model Name:
Kama Panel 3.5"
Model No:
SCKMPN-1000-35-BK
Weight:
104 g / 3.59 oz
Dimensions:
102 x 95 x 25 mm / 4.02 x 3.74 x 0.98 in.
Supported OS:
Windows Vista / XP / 2000
Controller:
Alcor Micro AU6375
Supported Storage Media:
SD Card, SDHC Card, MMC Card, miniSD Card, microSD Card, CompactFlash Media, Micro Drive, Memory Stick (Pro, Duo, Pro-Duo), xD Card (no Adapter required) - RS-MMC, MMC micro, Memory Stick micro (Adapter required, not included)
Fan Controller:
2 Channels
Connections:
1x USB / 1x S-ATA / 1x Front Audio (Headphones, Microphone)
Accessory:
Audio Cable (Jack to Pin-Connector), USB 2.0 Cable, S-ATA Power- and Data Cable, 2x 3-pin Fan Cable
For more information and illustrations, please visit our Web site:
www.scythe-eu.com/en/products/pc-accessory/kama-panel-35.html
