This press release is written by a third party and the content does not reflect the opinion of bit-tech's editorial team
Hamburg, Germany November 11th, 2009: Scythe Co., Ltd. presents the new Gentle Typhoon case fans developed by the Japanese Nidec Servo Corporation. Eight versions in two different sizes (92 and 120 mm) with different speeds will be placed on the market at the same time.
All eight versions have a newly designed impeller which has a high performance with very low background noise. All fans are manually balanced to guarantee operation with less vibration.
In comparison to comparable fans the Gentle Typhoon is characterized by a pleasant noise level. The innovative design of the fan blades were designed to avoid disturbing air which means less noise at high performance.
The motor of the fan uses a patented double vibration reduction structure which also prevents vibrations produced by the fan.
Gentle Typhoon Case fans are available for $11,95 / 6,40 € (excl. VAT, 92 mm version) and $16,95 / 8,00 € (excl. VAT, 120 mm version).
Model Name:
Gentle Typhoon 120 mm Case Fan
(500 rpm - 800 rpm - 1,150 rpm - 1,450 rpm - 1,850 rpm)
Gentle Typhoon 92 mm Case Fan
(1,700 rpm - 2,150 rpm - 2,650 rpm)
Model No.:
D1225C12B1AP-11 (120 mm - 500 rpm)
D1225C12B2AP-12 (120 mm - 800 rpm)
D1225C12B3AP-13 (120 mm - 1,150 rpm)
D1225C12B4AP-14 (120 mm - 1,450 rpm)
D1225C12B5AP-15 (120 mm - 1,850 rpm)
D0925C12B1AP-12 (92 mm - 1,700 rpm)
D0925C12B2AP-13 (92 mm - 2,150 rpm)
D0925C12B3AP-14 (92 mm - 2,650 rpm)
Manufacturer:
Nidec Servo Corporation (Japan)
Weight:
120 mm: 200 g / 6.46 oz
92 mm: 100 g / 3.23 oz.
Dimensions:
120 mm: 119 x 119 x 25 mm / 4.69 x 4.69 x 0.98 in
92 mm: 92 x 92 x 25 mm / 3.62 x 3.62 x 0.98 in
Technical Data:
120 mm - 500 rpm: 0.015 A - 5 dBA - 31 m³/h
120 mm - 800 rpm: 0.023 A - 9 dBA - 48 m³/h
120 mm - 1,150 rpm: 0.034 A - 16 dBA - 63 m³/h
120 mm - 1,450 rpm: 0.049 A - 21 dBA - 85 m³/h
120 mm - 1,850 rpm: 0.083 A - 28 dBA - 98 m³/h
92 mm - 1,700 rpm: 0.03 A - 13 dBA - 44 m³/h
92 mm - 2,150 rpm: 0.046 A - 20 dBA - 58 m³/h
92 mm - 2,650 rpm: 0.078 A - 26 dBA - 71 m³/h
Bearing Type:
Double Ball Bearing
MTBF:
120 mm: 100,000 h @ 35°C / 95°F or 60,000 h @ 60°C / 140°F
*1,850 rpm Model 55,000 h / 60°C
92 mm: 100,000 h @ 35°C / 95°F or 60,000 h / 60°C
*2,650 rpm Model 55,000 h @ 60°C / 140°F
Accessory:
4-pin Molex Adapter, 4x Screws
www.scythe-eu.com/en/products/fans/gentle-typhoon-92-mm.html
www.scythe-eu.com/en/products/fans/gentle-typhoon-120-mm.html
