This press release is written by a third party and the content does not reflect the opinion of bit-tech's editorial team
Scythe Co., Ltd (Tokyo, Japan) announces its newest CPU-Cooler. Together with Quietpc.com, there was a product developed which uses a unique design to fit everybodys’ needs.
The special angular shape of the cooler allows to optimize the airflow through a PC system by utilizing the PSU and rear case fans. For perfect compatibility and flexibility, Kama Angle can be mounted in four different directions.
Scythe supplies Kama Angle with a new ultra silent SlipStream-fan, which uses PWM. The PWM-technology allows a temperature-dependent regulation of fan speed directly controlled by mainboard BIOS and is supported by lots of motherboards available on the market. The supplied fan can be mounted in three different ways to supply optimal airflow inside the case.
Kama Angle is compatible with all current sockets. Mounting accessory for Intel Socket 478 and LGA 775 is supplied as well as for AMD Socket 754, 939, AM2 and AM2+.
Scythe uses materials of highest quality. The baseplate consists of nickle plated copper to avoid corrosion of the used material.
The Kama Angle can be purchased from now on for an MSRP of XXX $ / 29.90 Euro excl. VAT.
Specifications of Kama Angle CPU Cooler
Model Name:
Kama Angle
Model-Nr.:
SCANG-1000
Compatibility:
Intel:
Socket 478 All Speeds
Socket T / LGA 775 All Speeds
AMD:
Socket 754 All Speeds
Socket 939 All Speeds
Socket AM2 All Speeds
Socket AM2+ All Speeds
Measurements (W x D x H)
123 x 123 x 160 mm / 4.84 x 4.84 x 6.30 in
Fan-Measurements (W x D x H):
120 x 120 x 25 mm / 4.72 x 4.72 x 0.98 in
Fan Speed:
324 ~ 1,200 rpm ±10%
Fan Noise Level:
6,4 ~ 24 dBA
Air Flow:
14.43 ~ 68.54 CFM = 24.52 ~ 116.45 m³/h
Baseplate-Material:
Nickle-plated copper (more Infos)
Weight:
640 g (Heatsink) + 115 g (Fan) = 20.66 oz + 3.71 oz (fan)
MSRP:
US$ 49.80
For further information & images regarding this product, please visit our website at
Kama Angle Product Page (en.):
www.scythe-eu.com/en/products/cpu-cooler/kama-angle.html
