Palit Microsystems, leading graphics card manufacturer, after the release of HD 4850 Sonic further introduces astonishing HD 4850 1GB Sonic which equipped with 1024MB king size memory along with pre-overclocked 2000MHz memory speed and 685MHz core speed combining Palit’s own design innovative cooling system and power management technology offering another bliss choice to performance hunters.
Palit HD 4850 1GB Sonic edition with the 1GB Sonic naming theme symbolize the 1024MB king size memory along with pre-overclocked 2000MHz memory speed and 685MHz core speed is able to provide stunning graphics performance meanwhile offers extra memory buffer allowing users to enjoy extreme performance improvement while playing the latest DX10 PC games under HD large screen and high quality image (such as 8xAA.).
Comes with Palit’s innovative cooling system with two-ball bearing PWM fan, heat-pipes, and superior copper base to ensure high performance, consistent thermal, Palit HD 4850 1GB Sonic is able to dissipate heat efficiently, but remains in a quieter status; the GPU temperature is up to 20℃ lower than the original fan and the cooling system is 10dB quieter even at full loading situation! In addition, the 8-pin power connector design on HD 4850 1GB Sonic supports up to 150W enables overclocking potential with stability. The 3-Phase PWM power circuit on Palit HD 4850 1GB Sonic provides a more robust and stable energy distribution system allowing the graphics card to maintain a lower operating temperature.
Size does matters! Check out the King size memory with Palit HD 4850 1GB Sonic.
Stats: 0.032 seconds
