Scythe Round Shaped 140mm Equivalent Sized 120mm Case Fan
September 1, 2008 | 19:23
Companies: #scythe
Scythe Co., Ltd (Tokyo, Japan) announces another original designed 140mm dimension-surface 120mm case fan, “Kaze Maru”. “Kaze” means “Wind” & “Maru” means “Round” in Japanese language. 500rpm version of this case fan is used for Scythe giant fanless CPU cooler, “Orochi” CPU Cooler as a default cooling fan to generate super silent CPU cooler. By making the shape to be round shaped, the screw hole for 120mm case fan is build-in to this case fan, which means the case fan can be mounted into the 120mm case fan position yet generate the performance and maintain the silence of 140mm equivalent. Round shaped case fan is also unique design in the today’s hardware market.&nb sp; By replacing the existing 120mm case fan on CPU cooler or case fan with this “Kaze Maru” 140mm case fan, more gain in airflow and reduction in noise can be accomplished! 3 various fan speed can be selected, 500rpm for super silent purposes, 1200rpm for silent purposes, and 1900rpm for silent yet more power/airflow purposes. Depending on your needs and demands, this case fan can be the versatile product to fit your needs! For further details, please refer to the below specifications.
Model Name:
Kaze Maru 140mm Case Fan (500rpm/1200rpm/1900rpm)
Model-No.:
SY1425SL12L (500rpm version)
SY1425SL12M (1200rpm version)
SY1425SL12H (1900rpm version)
Manufacturer:
Scythe Co., Ltd. – Japan
Dimensions:
140 x 140 x 25mm / 5.51 x 5.51 x 0.98in (WxDxH)
Specifications:
10.80dBA / 29.39CFM (500rpm version)
26.58dBA / 61.30CFM (1200rpm version)
41.13dBA / 104.54CFM (1900rpm version)
Weight:
131g / 4.23oz (500rpm version)
137g / 4.42oz (1200rpm version)
175g / 5.65oz (1900rpm version)
Connector:
3-pin (3-pin to 4pin adaptor included)
Cable Length:
30cm / 11.81in
Bearing Type:
Sleeve Bearing
MTBF:
30,000 hours
MSRP:
19.99 (USD)
9,50 (EURO) excl. VAT
www.scythe-eu.com/en/products/fans/kaze-maru-140mm.html
