The release of V9 Chassis from Thermaltake today is certainly one exciting news for the PC gamers. Not just the stylish all black color pleasing our eyes at the first sight, but the tremendous 23cm top fan with a series of strategically designed ventilation system are also tickling our gamer desires!
V9 was definitely created for proud gamers at Lan Parties! To boost up the system performance for extreme gaming warriors, the air flow within V9 has been independently designed to focus on the four different heating sources in the chassis, CPU, VGA, HDD and PSU. The 23cm top fan that is impossible to ignore, works perfectly with the metal meshed front panel and rear fan. CPU cooling is further enhanced with one side fan and another optional fan installation on the motherboard tray. The second fan installed on the side panel is then strategically positioned to increase the air intake for VGA heating areas. Together with the bottom placed power supply unit and the 12cm red LED fan at the front for HDD cooling; the ventilation design excellence of V9 is equally stimulating as its stylish appearance!
It is also pretty easy to discover the extra careful touches for users on V9, like the dust filter included with the metal meshed front panel, the top tray for your installation tools or small hi-tech gadgets and the basic tool free mechanisms. Considering the ventilation, style, convenience, and future upgrading flexibility of a Gaming Chassis, Thermaltake V9 is definitely one marvelous new innovation!
www.thermaltake.com/product/Chassis/midtower/v9/v9_index.asp
About Thermaltake
Thermaltake Incorporation, based in Taipei, Taiwan is the global leader Thermal Solution and Thermal Management for PC & Industrial Market. Its engineering staffs master in Airflow Analysis, Material Conductivity and Heat Dissipation Efficiency. Thermaltake offers a wide range of products and services, providing effective and cost-conscious cooling devices. The Company has more than 1,000 employees worldwide supporting customers from its headquarters in Taipei, Taiwan, as well as from offices in China, Europe and United States Continent.
Stats: 0.030 seconds
