Unique Features for the PC-XB01
* Cooler Xbox 360 alternative chassis
* Black, hairline brushed anodized aluminum chassis
* Sound dampening foam and silent fan (120mm@1500RPM)
* Vertical or horizontal positioning
* Replaces original chassis completely (DIY skills needed)
Lian Li launches PC-XB01: the Xbox 360® Chassis replacement
Lian Li shows Microsoft how it’s done!
14 August 2008, Keelung, Taiwan – Lian-Li Industrial Co. Ltd will launch the PC-XB01 chassis for the Xbox 360 today. The XB01 is a chassis replacement for the XBox 360 chassis, which alleviates heating issues from hot components and reduces noise from vibrating optical drives in the original case design. The PC-XB01 requires DIY knowledge for the transfer of components, but once completed, heat will no longer be a factor in dampening your XBox 360 gaming experience.
Lian Li is an executive upper-class aluminum PC chassis manufacturer, well renowned as the ultimate brand for modding and stylish designs. Those same attributes are incorporated in the PC-XB01. Including an all-aluminum black hair-line brushed anodized chassis. The case has the traditional filed edges to reduce sharp corners, as well as folded and handcrafted aspects synonymous with Lian Li’s superior quality and high safety standards.
The PC-XB01 is 160 x 250 x 415mm (W, D, H), giving lots of space for copious cool airflow. The 120mm (1500RPM) rear fan draws off the heat from inside the case effectively and silently, while the ODD region is encased in stylized foam to reduce noise experienced from spinning disks in standard units.
All the Xbox 360 ports are hidden behind stylish dust covers and the ODD bay also has a spring loaded dust cover for aesthetic appeal and convenience. The unit can be placed horizontally, or vertically, depending on your needs, and the water cooling pipe holes are an option to use should you be inclined to do so. The case is designed to fit the entire Xbox 360 internals similar to the original, with the power transformer attaching from the outside.
The Lian Li PC-XB01 is the perfect complement to the Xbox 360 to alleviate heating issues. The stylish exterior gives your product a sense of class and will fit in with almost any living room environment. Microsoft Inc is very strict on warranties, so it should be noted that you will not be able to return your product if you use the Lian Li PC-XB01 alternative. With that being said, you are less likely to have overheating.
For more details on features for the PC-XB01 please go here:
www.lian-li.com/v2/en/product/product06.php?pr_index=261&cl_index=1&sc_index=35&ss_index=87
About Lian-Li
Lian-Li Industrial Co. Ltd is an Aluminum Chassis and Chassis peripheral manufacturer and provider of industrial wholesale as well as OEM & ODM services for the PC industry as required. With over 20 years of service excellence, ISO 9001 certification and a team of professional staff willing to do the utmost to deliver durable, superior quality products for your discernment.
About Xbox 360
Xbox 360 is the most powerful video game and entertainment system, delivering the best games, the next generation of the premier Xbox LIVE online gaming network and unique digital entertainment experiences that revolve around gamers. Xbox 360 has a catalog of more than 160 high-definition games and is available in 37 countries.
About Microsoft
Founded in 1975, Microsoft (Nasdaq “MSFT”) is the worldwide leader in software, services and solutions that help people and businesses realize their full potential. Microsoft, Xbox 360, Xbox LIVE and Xbox are either registered trademarks or trademarks of Microsoft Corp. in the United States and/or other countries.
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
