Scythe Co., Ltd (Tokyo, Japan) announces the new 100mm fan in super slim size! This product is originally equipped in the latest Scythe super slim CPU Cooler “Shuriken” to lower the overall dimension and weight of the CPU Cooler. This new case fan has super slim thickness (measured to be 100 x 100 x 12mm / 3.94 x 3.94 x 0.47 ic) to contribute the lower total height of your PC system. Just a case fan is simply not attractive for you? The item comes with the extra mounting kit for Hard Disk to conveniently convert this item as a Hard Disk cooler! Ideal replacement case fan for your HTPC system or simply to arrange your system to be more compact!
Model Name:
Kaze Jyu Slim 100mm Case Fan (1000rpm)
Kaze Jyu Slim 100mm Case Fan (2000rpm)
Model Number:
SY1012SL12L (1000rpm)
SY1012SL12M (2500rpm)
Dimensions:
Specifications:
14.5dBA / 15.23CFM / 12V / 0.09A (1000rpm Version)
29.22dBA / 27.60CFM / 12V / 0.16A (2000rpm Version)
Connector:
3-pin (4-pin adaptor included)
Cable Length:
30cm / 11.81 ic
Bearing Type:
Sleeve
MTBF:
30,000 hours
MSRP:
8.80 (USD)
4.15 (EURO) excl. VAT
www.scythe-eu.com/en/products/fans/kaze-jyu-slim-100mm.html
Stats: 0.021 seconds
