IBM has made a good showing in this latest list, accounting for almost half the worlds fastest computers.
The latest TOP500 list – a collection of the fastest supercomputers in the world – has been released by its creators, and there's some big wins for certain manufacturers.
The list, published this week on the
TOP500 site, gives the number one spot to IBM's
Roadrunner, built for the United States Department of Energy and hitting a staggering 1.026 petaflops/s – the first supercomputer to break the
petaflop milestone. According to IBM, the key to this remarkable achievement was the use of Cell Broadband Engine processors – the same chips that are used in Sony's PlayStation 3 console.
In fact, this 31st incarnation of the list has been extremely kind to Big Blue – IBM systems account for almost half the systems listed. Intel has been doing well, too: 75 percent of the systems present in the list use one or another of their processors, and systems based around quad-core processors use Intel almost exclusively.
Intel's growth has come at a cost to its main competitor, however: AMD sees its x86-64 architecture drop from 15.8 percent back in November last year to just 11 percent in this latest compilation. The company's Opteron processor, however, makes a welcome appearance in the
Roadrunner system, giving IBM's winner the grunt it needs to perform rapid general-purpose computing in addition to having blistering floating-point performance.
With Intel storming the charts, and IBM's radical Cell Broadband Engine proving its mettle, it's clear that AMD is going to have to pull something pretty special out of the R&D hat if it doesn't want to concede the high-performance computing market or find itself used as an accessory to more headline-grabbing processing engines.
Any of the figures from this latest list surprise you, or are you just gagging for a play with the
Roadrunner? Share your thoughts over in
the forums.
19 Comments
Discuss in the forums ReplyDon'tcha just love technology?
http://www.amd.com/gb-uk/Corporate/VirtualPressRoom/0,,51_104_543~126593,00.html
AMD Stream Processor First to Break 1 Teraflop Barrier
Next-generation AMD FireStream 9250 processor accelerates scientific and engineering calculations, efficiently delivering supercomputer performance at up to eight gigaflops-per-watt
It's some kind of add-in PCI card...
It seems they also want to utilize Radeons, FireGLs with some "AMD Stream SDK".
Nvidia will start to place itself on this list
Give it another 20 years, and it'll be in Mini-ITX... Then it'll be impressive.
not really. because by then they'll have something we can't even imagine yet. like star trek.
The new AMD stream processors should also be something to look out for, especially given its incredibly low power requirements.
Now if we see what sort of systems are they, the majority of IBM servers are using Opterons either alone or with Cell combined.
And a bit part of the HP server market is using Opterons too.
...looks like AMD has a home in the worlds fastest supercomputer, don't know why they wouldn't be happy. http://www-03.ibm.com/press/us/en/pressrelease/24405.wss
thanks for getting the exact numbers.
**Bit, please give AMD the credit it deserves in the article.
1: Roadrunner IBM (PowerXCell 8i 3.2 Ghz / Opteron DC 1.8 GHz)
2: BlueGene/L IBM (PowerPC 440 700 MHz (2.8 GFlops))
3: BlueGene/P IBM (PowerPC 450 850 MHz (3.4 GFlops))
4: Ranger Sun (AMD x86_64 Opteron Quad Core 2000 MHz (8 GFlops))
5: Jaguar Cray (AMD x86_64 Opteron Quad Core 2100 MHz (8.4 GFlops))
6: Jugene IBM (PowerPC 450 850 MHz (3.4 GFlops))
7: Encanto SGI (Intel EM64T Xeon 53xx (Clovertown) 3000 MHz (12 GFlops))
8: EKA HP (Intel EM64T Xeon 53xx (Clovertown) 3000 MHz (12 GFlops))
9: BlueGene/P IBM (PowerPC 450 850 MHz (3.4 GFlops))
10: SGI Altix ICE 8200 SGI (Intel EM64T Xeon E54xx (Harpertown) 3000 MHz (12 GFlops))
ya SpeeDj exactly what I was thinking, they might want to revise their sub header lol.
