Wembley, UK June 11th, 2008, ENlight UK, a wholly owned subsidiary of ENlight Corp Taiwan, has announced the arrival of its Micro-ATX Case, EN-2417
The case features dual front-side USB & HD audio ports with a snap-on piano black finish front bezel and build in card reader as well as excellent EMI shielding and thermal ventilation for high speed CPU’s.
Specifications:
Case Type: Micro ATX Tower
Main Board size: Micro ATX (9.6"x9.6")
Drive Bays: 2 x 5.25", 2 x 3.5" and 2 x 3.25"(hidden)
Expansion Slot 4 x Full Size
Power Supply 350W with 120mm fan
Cooling System 92mm rear fan and side panel airguide preinstalled
Dimensions 190mm x 360 mm x 480 mm
Safety Certificate Meets CE, FCC, UL, TUV
Chassis 0.8mm SGCC/SGCC Rustproof & Galvanized JIS steel
Currently available NOW at authorised distributors and resellers, the EN2417 M-ATX case will retail at around £49.99 + VAT.
ENlight UK Ltd launches ATX Case, EN-4116
The new ATX Case, EN-4116 features dual front-side USB & HD audio ports with a snap-on piano black finish front bezel and build in card reader as well as excellent EMI shielding and thermal ventilation for high speed CPU’s
Specifications:
Case Type: ATX Tower
Main Board size: ATX (12"x9")
Drive Bays: 4 x 5.25" (hidden), 1 x 3.5" and 4 x 3.25"(hidden)
Expansion Slot 7 x Full Size
Power Supply 450W or 650W 80+ options available
Cooling System 120mm rear fan and side panel airguide preinstalled
Dimensions 190mm x 431 mm x 474 mm
Currently available NOW at authorised distributors and resellers, the EN4116 ATX case will retail at around £39.99 + VAT
