Silverstone's new Raven logo.
Better known for its aluminium beauties, Silverstone has taken a curious turn to the extreme with the new Raven RV01 case.
The first thing you’ll notice is that Silverstone has basically
reinvented the case as we know it – the motherboard is angled 90 degrees pointing it upwards instead of out the back. This means the heat from the 200+W graphics cards can rise naturally and that plugging in your cables is far easier to see. There are two large fans in the base, while the PSU fan sucks in from the bottom to avoid funneling conflicts.
The case won’t be aluminium, but instead steel and a dull matt plastic (although it looks kind of rubberised) – Silverstone is keen not to use any shiny plastic that might make it look cheap. Design wise, well, it’s
aggressive that’s for sure, and it shouldn’t cost too much so it’ll be more accessible than many Silverstone high-end cases.
This model is the second engineering version from Silverstone, but it’s now coming close to final design.
When we met with Silverstone we also asked about the Fortress FT01 case, which has apparently undergone a couple of modifications, and were told that should be available sometime in July.
God-like or Ghastly? Let us know your impressions in
the forums.
They've 'reinvented the case as we know it' by turning the board 90 degrees? What about Lian Li cases that turn it 180 degrees? What have they done?
No, really, a case that looks like a tank and gives me an unfamiliar layout I have no use for, no thanks. I'll stick to my Lian Li. It's aluminium, doesn't weigh a ton and doesn't have the ugly prebuilt grey look inside it. Really, there's something about that grey color and the way the components in the cases look that remind me of 'old' cases.
What we need is a case producer to be truly radical, i propose turning the mother board 360deg, the cables coming from the back will be truly neat!
I want to know what the sales figures are like after a month..
And mines only a Asus TA-210 Black tower.
I stay with the minimal lines of older Silverstone and LL cases.
Wouldn't mounting it that way round screw up the heatpipes on the motherboard?
The main thing that really springs to mind is the ports coming out the top of the case. I mean - there looks like there's room for a bit of ducting there to keep things tidy, but name one time you've managed to get a DVI or VGA connector to bend at a nice tight 90 degrees angle? And if you look at even Lian-Li cases, most of them are now going back to the old "CPU at the top" paradigm, as Motherboard, HSF and Graphics Card vendors have designed their products to work best this way up.
However - as a bit of a side note - one thing would make this idea really really good. If they had a nice little "Patch Bay" inside, that routes external ports into the inside of the case, and into the motherboard external ports, that would be really quite nice. After all, it's the same paradigm as network or sound engineering patch bays - leave the MoBo plugged in, and a cheap external panel is used to plug in / un plug monitors, speakers, USB etc - that way its just a cheap port that gets metal fatigue or snapped off, not a part on a £200 motherboard...
Aaaanyway, if it wasn't for the motherboard laying drunkenly on its side, I think this would be quite cool - I like the idea of the PSU being inset in the bottom cavity, that's actually quite nice!
I've thought of making such a case - but with a minimalist look (the look isn't to my taste either but I wonder what a good modder could do with it). The biggest problem I saw was that the cable chase at the top would require too much space for the cables to bend (effectively making the case bigger) and in some situations may require longer cables.
So this is like taking the BTX idea but implementing it for AT? Interesting but routing those cables I think would become a pain in the ass.
What's taking so long with the first review?! ;)
well then if you do not like it then do not buy it or build your own
Before abandoning the idea of making a watercooled case (due to going to LAN's i didn't want to lug the case around) i toyed with this layout. albeit the board was turned -90°
idea, cables out the bottom, the entire top is the radiator. The entige case works as a chimney, cold air comes in the bottom, warm air rises and goes out the top.
Combine with a LARGE radiator (entire casetop and some big fans, that only turn on at certain temperatures) and you've got a very quiet case.
Problem 1: Most cables are too short for this. and you get an annoying lot of cables on the bottom.
Problem 2: the case needs to be very open, so you get dustproblems and hear the harddrives.
For this case: as the cables aro out the top, they should be long enough, but ugly. so they added a cablecanal. which disturbs natural convection.
Good to see someone question ATX though.
Still don't understand why the hot part of the graphicscard is usually th lower side though ;-)
