The Crysis hardware requirements have now been fully revealed.
Crysis is, without a doubt, the most gorgeous game we've ever seen. Even according to developers like Epic,
Crysis will be the best games can possibly look - for a while at least.
Of course, as Spiderman knows, with great power comes great...uh, system requirements? Until now, gamers have mostly been guessing about what hardware
Crysis will need. Now the specs have been released though, so check them out in full below.
Minimum System Requirements:
OS - Windows XP or Windows Vista
Processor - 2.8GHz or faster (XP); 3.2GHz or faster * (Vista)
Memory - 1GB RAM or 1.5GB RAM (Vista)
Video Card - 256MB **
Hard Drive - 12GB
Sound Card - DirectX 9.0c compatible
Recommended System Requirements:
OS - Windows XP / Vista
Processor - Intel Core 2 Duo @ 2.2GHz
Memory - 2GB RAM
Video Card - Nvidia GeForce 8800 GTS/640 or similar
* Supported Processors: Intel Pentium 4 2.8GHz (3.2GHz for Vista) or faster, Intel Core 2GHz (2.2GHz for Vista) or faster, and other similar CPUs.
** Supported chipsets: Nvidia GeForce 6800 GT + or similar GPUs. Laptop versions of these chipsets may work but are not supported. Integrated chipsets are not supported. Updates to your video and sound card drivers may be required.
Is your PC up to the task? Are you more concerned about how the gameplay is shaping up? Well, you can read either our
singleplayer preview or our
multiplayer preview to get an idea about the latter and you can boast about the former in
the forums.
My GFX card is what is recommended? Yea, 1024 @ max should be possible, maybe 1280.
Surprised they listed the nvidia 6800 as a minimum spec card, and not the nvidia 7x00 series.
Cool.
to specify an Intel only as "recommended system"
I think you should update your poor LCD and CPU to match with your 8800
I really doubt it. Perhaps, if you had a 8800 Ultra SLi setup with 4-8GB RAM, the speediest C2D on offer and matching components, you might stand a chance. But even then, I'd say that is a big perhaps.
I think I'll upgrade the monitor to a 22" when I have the funds to, seeing as most are 1650 x 1080 which won't put too much strain on the system. Processor wise, I think I'm fine and dandy for now since student funding means no Quad Cores for me :(
Don't discriminate AMD users!!! :(
i knew it was worth the extra money :D
Why is it that game companies still put things in Ghz? It's not like they're any indication of performance any more.
Well,
GHz indicates the same thing it always has, its not like it used to represent performance and now it doesn't. The problem is when they lay out a generalized clock speed without specifying a processor, because the clock speed only indicates performance relative to processor in the same family. Its weird that the minimum calls for 2.8GHz at the lowest, but the recommended calls for a C2D at 2.2GHz lol. They should really stay consistent with their identification schemes.
For Today's games the CPU won't give you much. It's the video card that does the major part of the work. Having a faster CPU will increase your speed but what? 10-15%, nothing major.
So the AMD Athlon 64 4400+ is correct in the specs.
E6600 2.4GHz
2GB RAM
Single 8800GTX
I wonder if my native of 1680x1050 will be possible with all the bells and whistles on.
Though that doesn't give any indication of resolutions, fingers crossed. This game is going to determine whether I get a 24" or not :o
ATM the code does seem to bog it down a lot, and if you look in the console there is a tonne of useless logging
