RV670 looks set bridge the gap between the Radeon HD 2900 XT and the Radeon HD 2600 XT.
Pictures of a non-working sample of AMD’s upcoming RV670 graphics processor – a chip designed to bridge the massive gap between the high-end and mainstream cards in the ATI Radeon HD 2000 series – have shown up on a Taiwanese website.
The chip
is rumoured to have been fabbed on TSMC’s 55nm process and will reportedly be clocked at 600MHz.
There will be the same 320 stream processors as there are in R600 (and are presumably arranged in the same way). However, RV670 is reported to only have a 256-bit memory interface – just half of what R600 has available.
This is connected to eight 32MB Hynix DDR3 DRAM chips, making a total of 256MB memory which is rated to 900MHz (1800MHz effective).
Additionally, the GPU will support CrossFire and the rumours suggest that RV670 will be Shader Model 4.1 compliant (DX10.1) along with also supporting PCI-Express 2.0. Our own sources have also confirmed that the GPU will integrate AMD’s Unified Video Decoder.
The card pictured has a single slot cooler and a single 6-pin PCI-Express power connector. These should be as a result of the benefits of moving to 55nm and also from PCI-Express 2.0’s increased power draw through the interconnect, which is up to 150W from 75W on older versions of the specification.
DailyTech also reports that the card
is expected to appear in AMD’s lineup in Q1 2008 and at this time pricing hasn’t been finalised.
Obviously, the card isn’t going to be as fast as a Radeon HD 2900 XT, but won't be far off either – will this take the mid-range to where it should have been originally?
Let us know your thoughts
in the forums.
Should make an interesting christmas!
Unfortunately, that's only out of character for nvidia. ATI's midrange cards are usually fairly disappointing at first with some decent refreshes later on in the cycle.
I hope the reduction to a single 6-pin power connector has nothing to do with the PCI-Express 2.0 power allotment -- that would imply that the card couldn't work (or at least wouldn't get enough power to run at full speed) on any of the PCI-Express 1.0 boards that have sold over the last several years.
Or maybe it draws 150 Watts in total, so on a 2.0 board, you don't even need to plug in the 6-pin connector, and on a 1.0 board, it'll get power through both the motherboard and the 6-pin?
Is it also amusing that the watermark on the pictures is nv6800? cause that makes me think of nVidia 6800.... and its a ATi card? no? just me? ok....
So much for ATi being green...
Edit add (talk about going off half cocked..)
I'm waiting for a decent mid-range DX10 card myself, somehow if this is going to be less powerfull than the GTS 640mb/2900 region I doubt its the card for me :(.
Kinda waiting for Nvidia to come out with 89xx or 9xxx I think, though unless AMD can pull together major competition soon, anything nvidia do eventually release is likely to be hideously expensive still.
The cards are far more limited by other things then the bus
