The Lenovo ThinkView is the first 22" monitor with a resolution of 1920 x 1200 pixels (WUXGA)
Lenovo may have just won my heart with the introduction of its latest monitor. The ThinkVision L220x is set to be the industry's first
affordable 22-inch WUXGA.
WUXGA (Widescreen Ultra eXtended Graphics Array) is the industry standard specification for a 1920x1200 display. At 22-inches, that works out to be just a little over 100 pixels per inch. All of this means that you'll be able to watch 1080p movies in all of their glory on a much smaller monitor than you could before.
The high resolution isn't the only selling point though. The monitor supports a built in four port USB hub, landscape to portrait rotation, a tilt/swivel/pivoting stand, and built in cable management. Full specifications of the monitor include goodies such as: 1000:1 contrast ratio, 6ms response time, 92 percent colour gamut, VGA and DVI-D inputs, HDCP support, and a 178°/ 178° viewing angle.
The ThinkVision L220x is set to debut in November for right around $550. This is sure to give several other, larger monitors a run for their money if the panel lives up to its specs.
While we wait until November to see just how well this monitor compares, check out a couple of pictures below. Don't forget to leave your comments on it
over in the forums or in the comment section below.
22 Comments
Discuss in the forums ReplyYeah, but the 22" will look a lot sharper then the 24" at the same resolution. I've been wanting to pick up an LCD for some time now (yesh, I still use a CRT when I'm not on my laptop) and I might just give this Lenovo a go.
Is it? What about EIZO CG221? http://www.eizo.com/products/graphics/cg221/index.asp
i think you'll be waiting quite some time - and don't u mean inputs anyway?
I see the story has now been updated. The Lenovo is US$550 so should come in under £400 (still cheaper than plenty of 24" of the same resolution). For reference, I found the EIZO CG221 for £2,800 (over US$5,000!). So this ThinkVision is still big news because it's the first consumer-level WUXGA 22"
Well a 30" WQUXGA display might not be too far off and Samsung has been experimenting with Dolby's IMLED technology so the two may meet in the not too distant future :)
I definitely mean outputs, DVI, Displayport, HDMI, Component, etc...
And this is great news! Screw 22"-ers with 1680x1050-resolution and TN-panels!
P
ah, i'm still not used to getting ripped off
that is also my question.......
bot:
Although i like the idea of a 1980 resolution on 22". I allready have a hard time reading words on my 1650 reso 20" widescreen. I rather have a cheap 26" or higher with 1980 res. with makes it more usefull as both monitor and moviescreen.
Umm I mean inputs :D
They were bought by Dolby in February: http://www.bit-tech.net/news/2007/02/27/dolby_buys_brightside_technologies_hdr_lcd/1
So when JADS refers to "Dolby's IMLED technology" he's talking about Brightside (the IM stands for Individually Modulated btw)
Why is this taking SO long to get to market?
