Manhunt 2 is coming...albeit in a slightly edited form.
Manhunt 2 has been hounded by the press ever since it was announced. "
Too much gore! Too much violence!" has been the common decrees from everyone that has tried to prevent the game from being released. Rockstar almost won too, with the game getting an "AO" rating from the ESRB which meant that even if any of the consoles agreed to releasing the game, there wouldn't be many stores that would actually stock it.
Many of us thought that would be the end of the game or, if it managed to come out, it would be a dramatically stripped down version of its former gory self. Well, it is still coming and this time with an "M" rating - in order to get this new rating, Rockstar had to cut out some of the content.
Just what did they cut out? Well,
IGN had the chance to preview both versions of the game and you'll be happy to know that this isn't going to be some watered down version of the original "AO" title.
In fact, not a whole lot has changed in the game; blood splattering, decapitations, and stabbings are all present and correct. You'll still be able to use the environments to kill your enemies in a variety of ways such as using a manhole cover to decapitate a hunter or bludgeon them to death with an enormous variety of blunt objects.
What has changed, however, has been the death strikes. Much like the fatalities in Mortal Kombat, you'll be able to go through a sequence of button presses or motions in order to murder your opponent in a variety of gruesome fashions. In the original, "AO" version of the game, these scenes were as clear as everything else.
Now Rockstar has used a combination of heavy blur effects and darkening the graphics in order to make it nearly indistinguishable. You'll be able to see the basic motions of the murder but IGN states that you'll have a hard time making out just what is happening.
While it may be disappointing to some that the scenes have been edited to the point of not being able to see them, at least the game is shipping without tonnes of content being removed. Planning on picking up a copy of the game when it's released this Halloween? Does the slight editing effect your decision to pick it up? Discuss it with us over
in the forums.
14 Comments
Discuss in the forums ReplyEither that or my English skills are a lot worse than I think they are and I should be ignored :P
Thanks, I missed that one :p
I was going to say:
"Not a chance after the trouble they got into over hot coffee. New submission rules mean you have to show everything on the disc, not just everything accessible through normal gameplay. Rockstar don't want to fund another recall for what is after all just a small game in their portfolio - they've spent enough on it as is they'll want to get it out and forget about it."
but now i think about it, if they are just engine effects it'd be quite easy to change values for light levels and motion blur. maybe there will be a simpleish work around.
But still, three days tops.
Manhunt was always about the mood, this was what they had objected to, fairly certain the graphic death scenes just took a backseat to everything else... kinda lost all hope in this now, decapitating someone kinda looses the edge when they cut it to the Benny Hill tune, talk about dumbing down...
