Venturer Electronic's SHD7000 is expected to be one of the cheapest HD DVD players on the market.
If you've been waiting to decide which high-definition format you're going to side with due to prices, then this might be the push for you. Venturer Electronics, a company primarily known for budget priced consumer electronics, has announced its first HD DVD player for the North American market.
The SHD7000 will offer 1080i video output over an HDMI connection, ethernet connectivity, Dolby TrueHD and the ability to upconvert standard DVDs to "near HD picture quality."
An exact price hasn't been announced but retail prices are expected to be one of the lowest. Of course you can expect to see it on the shelves shortly as the holiday product push is coming up on us very fast.
If you don't feel like waiting another month or so before you pick up your HD player, then there's a deal for you going on right now over at Amazon.com. With the purchase of a PS3 or HD DVD add-on for the 360, you'll get
eight free movies of your choice. Of course the HD DVD bundled
King Kong counts as one of your movies so you only get seven HD DVD movies of your choice.
If that sounds like it's something up your alley, then head on over to
Amazon's high-definition section to get a full list of eligible titles.
Is a cheaper price going to be the primary factor behind your purchasing decision or are you still holding out for a definitive winner? Tell us your thoughts over
in the forums or in the comment section below.
29 Comments
Discuss in the forums ReplyPs: Is Amazon's deal open to UK customers too?
It will depend on how I feel that morning ;)
If you read it says when you order your drive it comes with King Kong you then pick an additional 2 to get then at the top theres link saying you download it print it out and send it off for the other 5 movies or sommit when youve got your player.
Its located at the top of the page
I think there's still a huge knowledge gap when it comes to HD. A lot of people are still buying HDTVs under the assumption that their current DVDs are somehow magically displayed in high definition.
-monkey
I was watching "Modern Marvels: 80's Tech" last night and they talked about the betamax vs vhs format war. The said the vhs won out because jvc licenced the technology to others which brought the price way down. They also said that vhs, at its first introduction, could do two hours of movie. Beta had better definition which made it only able to record one hour of movie. Which since movies for are roughly two hours that kind of prevented beta moving into the movie rental realm and triggered a movie rental bonanza for the vhs format. They also mentioned the porn thing where the porn industry had chosen vhs as its format which pushed vhs as well.
only? in this case i think it is more than enough for a cheap player.....
Edit:
Making it a standard dvd drive is far more work then its really worth, leave it as usb and you will be fine.
The 360 HD DVD is only like £100 so that's pretty awesome compared to the £300 odd of the standalone ones.
Didn't really think that one through fully. I was thinking every household would have a 360 anyway as they're so awesome ;p
HD-DVD holds no more double that of a standard DVD disc right? And its just a video disc, so far.
Blu-Ray is 25Gb(?) for movies, and is also available as a storage format if you have a Blu-Ray burner drive. Thats really the only 1-up that Blu-Ray has over HD-DVD right now.
anyhow after looking at the rebate, its a MS rebate not amazon so I dont have to return the HD DVD I bought from BB and just use the rebate to get the 5 HD DVD... WOOT, but I still like my blu-ray but its good to have both covered...
The specifications are easily available from Wikipedia for both HD-DVD and Blu-Ray.
In the first sentence:
HD-DVD can store data as well as video content. Also, the capacity for HD-DVD is at least 3x that of DVD for single layer. Double layer discs can store up to 30GB. At the January 2007 CES, Toshiba demonstrated a 51GB, triple-layer disc.
Blu-Ray discs can store 25GB on single layer, 50GB for double layer.
-monkey
3 months in the US and 1yr in the UK
-monkey
it's easy to get one for £150 (base model) these days
