Unique mesh design simultaneously provides sleek styling and superb thermal performance
When it comes to PC chassis, no one does it better than Cooler Master. For years now, Cooler Master has been on the leading edge of PC chassis design. Today, Cooler Master is pleased to announce its latest creation – the CM 690 PC chassis. By utilizing a unique mesh design, the CM 690 effectively blends together both form and function, offering users a mid-tower chassis without compromise.
When looking at the CM 690, it’s easy to be taken in by its bold lines and superb styling. But don’t let its exterior fool you – the CM 690 is a lot more than just a pretty face. Its unique Cooler Master mesh design not only gives it its modern good looks, but also facilitates excellent thermal performance. Inside, users can install up to seven 120mm fans for high-efficiency ventilation, making the CM 690 perfectly suited for today’s high-powered hardware. A 80x15 mm fan can even be installed at the rear of the motherboard tray to keep the CPU area well cooled. Other innovations like the bottom-mounted power supply, top mounted ventilation holes and retaining holes for water cooling units makes the CM 690 the ideal choice for systems that require the utmost stability.
With its unique design, superb thermal management, roomy interior, and smart design touches, Cooler Master has once again raised the bar for mid-tower PC chassis with the CM 690.
About Cooler Master
Cooler Master was founded to provide the best thermal solutions to our customers worldwide. Since its establishment a decade ago, we continue to invest in product development in order to provide the leading-edge innovations to people and businesses. Cooler Master’s enclosure technology line-up includes heat sinks and fans, chassis, power supplies, function panels and accessories. Cooler Master has its headquarters in Taipei, Taiwan, with global branch offices located in Europe, America and APAC, so that we can offer to our customers the best service in time. For more information on Cooler Master, please visit www.coolermaster.com.
Stats: 0.030 seconds
