DDR2 Patriot Memory @ PC Stats
bit-tech's web reviews round up featuring some other reviews and features from around the net for you to pass the time on. Not that you should go elsewhere until you've read today's EVGA nForce 650i Ultra review though!
Hardware
Software
Seen anything interesting? Let us know in the forums.
Quote Techno-Dann 20th June 2007, 01:20
I'm not sure who they think they're fooling, the Black Pearl WCR is a Lian-Li. Look at it: Overall, it's a V-2000. The CD-ROM stealth bezels and the floppy bezel are straight off a V-2000. There's the right number of 5 1/4" bays, too. (7). On the top, the door for the USB/audio/firewire jacks is exactly like the one on the front of the PC-7H and the top of other, newer Lian-Li cases, not to mention the fact that it's the exact same port block as Lian-Li's been using for the last three years.
The hose ports at the back are precisely like the ones off the Lian-Li PC-A10, and the entire back of the case is a transplanted V-2000: They even used the same shiny PCI slot covers. The six-hole mounting for the PSU cover plate is exactly the same as a V-2000, as are the slots around the rear fan for the (not included) rear fan duct.
It gets better, too: The mesh that the PSU sits on is precisely like the one in a V-2000. The side pannel attachment points are precisely like a V-series Lian-Li. The mounts for the side mesh? Once again, precisely like the ones used on L-L's V-series.
The insides of the case should be remarkably familiar to anyone who has worked in a Lian-Li lately... The only real difference from the V-2000, the hard drive racks, are borrowed from the PC-A10.
On the off chance that that case is not built by Lian-Li, I predict there will be legal action very soon.
(edit) That said, it's a rather nice looking Lian-Li. I may be buying one, if I can find one in silver. (/edit)
Stats: 0.116 seconds
