Cooler Master's Cosmos is almost ready for launch.
We first saw Cooler Master's latest chassis at CeBIT, but back then it was in the very early stages of development. We're now fast approaching the launch, which will happen in the next few weeks and the case's design is just about finished.
There have been some changes made since we first saw it, a lot of which were discussed in a meeting I had with the case's product manager during a visit to Taiwan in April.
Interestingly, the case uses negative pressure to ensure that there is enough cool air inside the chassis - there is one intake fan and three exhausts, two on the top and one on the back, all of which are 120mm units. Unfortunately, the two on the top aren't close enough together to attach a 2x120mm radiator for watercooling.
However, the bar that sits across the middle of the chassis isn't just another useless piece of plastic because, thanks to the way that the case uses negative pressure, it draws cool air in through the vent on the back of the case, over the graphics cards. There is also the option to install a 120mm fan into this bar, giving even more airflow over your high-end and potentially very warm graphics cards.
The foam cable routing canal has been removed and replaced with a couple of holes for routing cables - this is a far better solution than the original idea, but the cabling still looks a little messy (in Cooler Master's attempt on display). All of the rest of the features we outlined at CeBIT still look to be there, and we'll be giving the case a full review as soon as we get our hands on one!
As far as pricing, it's looking quite attractive - Cooler Master expects the case to go on sale for around £120 (inc VAT), which is much less than we were expecting. I'll leave you with a few pictures, and you can discuss the new chassis in the forums.
Quote Hiren 13th June 2007, 17:23
Wow, that's fudgy. For £120 there way nicer looking cases about.
Quote Bluephoenix 13th June 2007, 17:53
I'll await the bit review before thinking about buying.
good to see they kept the HDD enclosure concept
Quote Fod 13th June 2007, 18:01
looks hideous tbh
Quote Krikkit 13th June 2007, 18:09
First thoughts: hideous.
Second thoughts: better.
It's starting to grow on me tbh, alright it's not really plain, but it's enough imho, and the cooling looks awesome. I'll wait for the BiT review, then make a final judgement. ;)
Quote XeroNXS 13th June 2007, 18:40
Looking quite good imho. :)
But for 177€ I can probably buy a better looking aluminum case.
What I don't get is why Cooler Master wasn't able to build a proper rig.
It looks really messy inside.
Quote Tile 13th June 2007, 19:08
I don't like it at all. Coolermaster could have done way better.
Quote cool_dude 13th June 2007, 19:10
Discusting.
//Wishes ATCS would come back to them....:(...
Quote ./^\.Ace./^\. 13th June 2007, 19:13
It needs some work. Maybe a hamer could fix it :D
Quote stevehp 13th June 2007, 21:23
However, the bar that sits across the middle of the chassis isn't just another useless piece of plastic because...
What bar? The images on this site are always too small and not expandable if you're going to point something out zoom in on the image or whatever to get your point across.
I know what bar(duct) you are speaking of Antec had them in the older P180s horrible solution made way too much noise.
Quote DXR_13KE 13th June 2007, 22:03
put the fans closer and make it a little cheaper and you have a deal.... after i read the review..... :D
Quote Tim S 13th June 2007, 22:14
My apologies - hectic first day back in the office... :o
Check here: http://www.bit-tech.net/news/2007/03/15/cooler_master_shows_concept_case_design/1
I'm referring to the bar that runs across from the rear I/O to the drive cage. I know a lot of manufacturers have used similar "bars" for "extra support" but this isn't about that load of rubbish, it's more of an air duct than a bar, I guess - I'm in bad habits from times of old
Quote Cupboard 13th June 2007, 22:24
Are the things that look like handles actually handles, or will they fall off if you try and lift the system with them?
Quote Tim S 13th June 2007, 22:32
I believe that the current cases are handmade, so it's not recommended. But on the retail cases, these should be "handles", afaik.
Quote Duste 14th June 2007, 00:26
Are those bars on the top and bottom fully functional handles, or are they just there for show?
Quote CollinstheClown 14th June 2007, 00:56
Read about... one post up...
-CollinstheClown
Quote zr_ox 14th June 2007, 07:04
Now that's just hiddeous.
I like that they have moved the PSU to the bottom though,
is there a vent under there so that there is cooler air for the PSU? All cases should place the PSU at the rear base of the case.
It looks like cable routing will be the toughest part of making that case look good. I cant believe they chose to showcase that with such terrible cable management, if they had spent 3 minutes more on that, added watercooling it would really help make the rig look better.
Shame that the plastic they have used makes it look so cheap. I know it's £120 but they could have pulled of something a little mory classy...it looks like something from the set of a very bad F Class Sci-Fi movie.
Quote wharrad 14th June 2007, 12:49
Ach Coolermaster went wrong when the guys that now form Silverstone left. ATCS cases were great with the understated design and all brushed ali. It just seems to me that now they use their good name to put high prices on lower quality steel/plastic cases.
Silverstone or Lian-Li is the only way forward at the moment.
Quote Delphium 14th June 2007, 13:25
The hard drives looks like there stack sideways at the bottom, which concerns me with regards to keeping them cool due to restricted air flow across them :|
Quote Atomic 14th June 2007, 13:58
Those were indeed nice cases.
Quote Mother-Goose 14th June 2007, 16:53
I see some kind of father ted moment.
Quote Koradhil 15th June 2007, 17:54
I knew from the start this was going to be a controversial case. I had a chance to see the initial prototype in real life at CeBIT 2006 in a small and dark room at their booth. Last CeBIT they showed the new prototype and I have to say the case has had a lot of improvements. The brushed aluminum just looks great with the glossy black acrylic.
The handles are really the most unique feature of the case, and will certainly not appeal to all. They are functional though, sturdy enough to lift the case up.
A nice feature is the possibility to place a dual 120mm radiator at the top of the case. Unfortunately that will require some modding, but it certainly can be done. Another nice thing is the padded sidepanels which will kill most of the system's noise making this a really quiet rig.
I can't wait to get my hands on one of these, fortunately for me it looks like CM will send me one for another casemod project.
Stats: 0.113 seconds
