We think ThermalRight might just have won the award for the show's largest heatsink this year...
As we were walking around the show, we came across an interesting chassis design on ThermalRight’s stand earlier today – it’s a massive heatsink.
In many respects, this is nothing new, as Zalman has been selling cases that act as massive heatsinks for quite some time now. However, we’ve never seen anything quite like this.
The chassis we saw looked to be styled for use as an HTPC case, but instead of being a solid design with panels, it’s a massive array of fins. Zalman’s previous TN-series case designs have been panelled designs, but this thing is quite literally a heatsink.
Inside, there’s a base plate that comes into contact with your processor, which is then connected directly to the main body of the case, which is quite literally a giant heatsink. We’ll leave you with a couple of pictures, because as the saying goes a picture tells a thousand words.
Don’t forget to drop by our forums to
share your thoughts on ThermalRight’s interesting ideas.
When? and How Much?
the zalman one was not very popular either and was very expensive.
I wouldn't worry about sharp edges, transport, etc. though - that case will be extremely rigid and all sharp edges will be deburred before sale.
One other possible issue is cooling other parts - the case seems only to cool the CPU, and if you try to go fanless that means other parts like your PSU, GPU, MOSFETS, etc. will get rather toasty...
But props for creativity
Is it meant to be passive, or are there fans hidden beneath the mess of fins?
-monkey
I don't think the dust will be a massive issue. In my experience heatsinks get loads of dust because of the fans. This doesn't have any.
I'd assume the engineers at Thermalright know what they're doing, but my guess is that a lot of that extra surface area and weight is more for looks and that coveted "biggest heatsink" () prize than functional heat-dissipation.
Maybe I'm wrong, though.
I'd still like to have one. :D
I wonder if covering the chassis top with 120mm fans will make a silent and powerfull cooling solution.
'Hangs head walks slowly back to the drawing board swearing and thinking!'
or one of those monster 250mm slow fans. on the top - drawing air out.
that does seem to be a fairly glaring flaw... and any removable modules for different boards type system will just kill the ability to transfer the heat....
if they put like a light over lay of metal around it to protect it, that would be better.
or some acrylics
i dont know about too much, perhaps its not too much, just unecessary surface area. though there is alot of metal to conduct heat into, great so long as you can get rid of it via convection or something.
thing is, for cooling a fin, its best to have a turbulent flow of air over it. if its a laminar flow it cooling effect is reduced, but long fins are best.... if the flow rate is right it'll have more chance of becoming turbulent at some point along the fin.
i have the calculations some where.
apparently, there are outer panels - the gifreakingnormous heatsink is actually on the inside of the case.
