"It's not in what you see, but what you don't" -- IBM has found a way to create vacuum insulation.
We've been wondering for some time now how close we could get to breaking Moore's law with current chip fabrication. Some people expected that we'd start to see a decline in processor growth. Others, like myself, just contently sat back waiting to see who would build a better mousetrap. And the answer is unsurprising -- it's IBM. With a little help from mother nature, of course.
IBM has developed a new chip fabrication that can allow for a considerably more dense chip that actually takes less time and expense to create than standard methods. The "secret" is actually growing the chip to create vacuums inside of it as an insulator, rather than requiring a separate process.
In normal chip fabrication, a special insulator is put around the copper wiring, which is then etched off of the necessary contacts by a light process and a chemical bath. This process is both very expensive and very prone to error, causing dead chips and wasted silicon.
Further, an insulator is not a guarantee -- if the insulating layers get too thin, current can still cross through them. This failing has been one of the two primary reasons for an inevitable conclusion to Moore's Law (the other being wire thickness) under current fabrication conditions.
The new process uses a dissolving glass that creates vacuum pockets in between the wires. In physics, a vacuum is actually the most perfect insulator, as there is nothing for the electricity to flow across. Therefore, these pockets can be smaller than current insulating techniques. As an added bonus, they don't require the same expensive light etching process, which reduces cost and environmental by-product (etching solution is not exactly environmentally friendly).
To develop the design, IBM had turned to nature, which uses a similar process to create snow flakes, tooth enamel, and seashells. Of course, the plan had to be deviated from slightly - the natural order makes almost every vacuous pocket unique in size and shape, which wouldn't work in a chip design. IBM's technology, in comparison, creates uniform pockets. I guess some things are still better left to nature.
Do you have a thought on the new process? Tell us about it in our forums.
Quote Echo 4th May 2007, 16:37
wow. its a wonder we really need desktop sized cases anymore.. or even mini-itx for that matter.. how long before the matchbox computer is released? :p
Quote Echo 4th May 2007, 16:40
Lol. I thought I'd google it before someone else did... http://news.bbc.co.uk/1/hi/sci/tech/276762.stm
EDIT: And that was 8 years ago!
Quote kenco_uk 4th May 2007, 16:41
So, when I'm using my vacuum cleaner of the future, it'll suddenly have a mind of its own, burst out the door and suck up the neighbour's cat?
Quote alextwo 4th May 2007, 16:45
Anyone else think that picture looks like a giant mattress?
Quote Tim S 4th May 2007, 16:52
It is :D
Quote Tyinsar 4th May 2007, 18:57
Pico-ITX looks SO Huge now. ;)
You say that like it's a bad thing.
Quote Zyphron 4th May 2007, 20:24
IBM: think different....... Err wait ....
sounds like your Chip can now "pop" like a light bulb...
Quote Bladestorm 4th May 2007, 22:16
Cool :)
Quote L2wis 4th May 2007, 23:58
imaginative designing :)
Quote BlueDemon 5th May 2007, 00:12
As there is no water involved in the production process, I guess you meant for the title to read "au naturel", as opposed to "eau naturelle" which means natural water (spring water) ?
Quote DXR_13KE 5th May 2007, 01:14
Awesome!!!!!!
only IBM can come with this stuff to lighten up my day :D
Quote pdemon 5th May 2007, 03:27
so when does this get me cheaper chips!?
:D
Quote DarkLord7854 5th May 2007, 06:13
Correct spelling/syntax would be "goes au Naturel" I spose though it still doesn't exactly make sense
Quote Burnout21 5th May 2007, 11:42
i give a few years before the current shrink process just gets to small, i think that was said when we were at 900mhz and the production of 1GHz+ chips was impossible! lol
well we all know the future of computing and thats deadicated cores for certain jobs.
love to have a quad core, with software that can make use of the cores. i.e multi core gaming.
Quote smoguzbenjamin 5th May 2007, 16:18
"au naturel" would make sense, but now it says "IBM goes natural water"
Quote Dr. Strangelove 7th May 2007, 13:28
:D
Well the BBC article says that IBM expects to have chips in 2009, then IBM will probably give this tech to AMD... how long it will take AMD to make chips with this tech I have no idea...
And naturally we know that the computer industry never have delayed products and their predictions are always precise :(
Quote DarkLord7854 7th May 2007, 14:44
Just like the game industry is always on time right? :)
Quote Fiber4now 10th May 2007, 11:33
This is pretty funny coming from a company that has not gotten 65 NM out the door yet. I guess when you are huge as IBM is you can stand the heat that another huge corporation like Microsoft must be giving IBM for the last 6 months over the continuing saga of the Tricore PowerPC 90 NM that was supposed to be shrunk already. All I got to say though is IBM is the King of hype first it was SOI , then High-K metal gate, Nano-tubes and now what looks like foam rubber. LOL, it does look like a sleep easy mattress
Stats: 0.119 seconds
