Windows Vista activation is cracked. Quelle surprise?
With some clever Registry trickery, hackers have found a way to permanently delay the activation of 32-bit Windows Vista.
A previous hack last month involved setting up a spoof key server to generate faked license keys for the corporate version of the OS. This hack, which is rather simpler, avoids running the key server entirely.
In fact, it doesn't even require the input of any keys at all.
Vista runs, out of the box, fully functionally, for 30 days without requiring activation. This new hack stops the countdown timer at 30 days and makes sure that it never goes further - thus giving the eager pirate a fully functional version of Vista.
The hack,
covered by Engadget, probably won't work on 64-bit Vista, thanks to the security improvements MS has made in that version of the OS. You can also bet that Microsoft isn't going to be sitting around with this exploit in the wild - expect the first batch of Vista Windows Updates to address this.
Are you running Vista? Let us know your thoughts
over in the forums.
they will be checking the regkeys for all windows updates now -- so if you do that, your updates wont work -- and you will not pass the WGA checks -- and get revoked back to the limited status... yay!
or.. just block all MS data out of your network on a hardware firewall and hope.
It doesn't actually activate Vista, just disables the timer that tells Vista to prompt the user to do so, and leaves it in the "Initial Grace Period". Microsoft will find it very simple to detect this, I'm sure.
Unfortunately I've not been able to do much else with the copy of Vista I got through MSDN since my PC isn't very well supported seeing as it's got an nForce2 chipset. :( Every time I try to install the official Nvidia drivers for my GeForce6 card, it bluescreens, and I can't get any more than 2 speaker audio which sucks.
I've seen more BSODs in Vista than I've ever seen with XP!
Now they do it and [almost] everyone accepts it? You've paid for the damn software. Cha-ching, thank you, see you in '08 for Vista 2.
XP's activation was bad enough, but acceptable. If it's so easy to crack, the answer is to make it impossible to crack. Not to have you re-activate constantly whilst checking up to see if you've tried to re-engineer something. Doing so is only one step short of sending a lawyer around to look over your shoulder.
Ubuntu, dual-booted with XP Pro, is looking increasingly popular.
Might try rubuntu actually! :D
aka: well on the way to being fixed
Yes it does bother me and that's why I'm running linux. It's MY computer and I am the only one who says what goes on it, not MS, thank you.
Vista may be the greatest gift ever to the FOSS movement.
Roll on publically released buisiness activtion codes.
and bypasses will be a dime a dozen, it's more in the patch/upgrade path that whether or not the continue to work will be questioned
And on the topic of Linux, it's far more versatile, accessible, powerful, and cheap. It'd be great if only there weren't two limiting factors: It's unsupported by anything commonly used, and it's bleeding hard to learn how to use all of it's power. Make Linux easy to use (already is with some distros I guess) and make it common and Windows is out of business. Same with the Mac OS probably, but I root for Linux over that...
I say good job hackers! Keep them on their toes! Show them that they can't control us and our PC use!
Edit: Changed "great" to "a bigger accomplishment" since my original wording sounded like I condone piracy, which I don't.
Psh - as if Microsoft is that swift in making software revisions (Vista?)
I know what you're getting at. I don't like the thought of my software calling home. Just like when I buy a video camera, I want to know it's not sending video back to the company.
I don't agree with calling back constantly however, thats just perverse.
I don't mind it if I do an update on security issues that Microsoft know how often I check for updates and how often I use my machine. If however they modify my registry I'll be angry.
*Goes off to make a registry monitor*
And it's still not what they originally said it would be. Where's WinFS, for example?
I can see MS releasing another similar product in a few years. Think what Windows 98 was to Windows 95 -- similar, but with a few changes. Though with the added speculation of Vista's delayed mass-adoption, they might just shoot themselves in the foot.
But marketing aside, I don't think they want to wait another 5.5 years before a product release. Little and often is the way forward.
I'm sure there was an article on the Inq about it not so long ago, but I couldn't see it.
Im sure a more permanant solution will be found soon enough.
