"Of mini-fridges and windows" - Kustom PCs has done a nice job with this one. Throw in a peltier and chill a beer in it!
Though it's not necessarily "hot news," we figured a few of you might enjoy this tidbit.
Many of our forumites have expressed interest in the Antec P180 case
ever since our review back in January. In amongst my glowing commentary about the case, I had noted one shortfall at the time - the low-noise panels that created the wonderful acoustic properties were not exactly modder-friendly. Since the case provided no real windows, it wasn't going to be high on the list of anyone looking to truly spice it up.
Well, so much for that. It may be ten months down the line since then, but the boys over at
Kustom PCs have done it. The site now boasts a new P180
pre-modded with a window - one that doesn't even kill the noise reduction quality of the case. The window complements the look of the "mini-fridge" quite well.
For those that roll their eyes about a pre-mod, I encourage you to take a look around online. Cutting these panels is
hard and (from what I've seen of attempts) usually comes out looking horribly while simultaneously trashing the acoustic properties. It's just not a mod that's worth doing yourself - and now you don't have to.
So for everyone who is interested in this rather wonderful case but wanted a window on it, head on over and check it out. It's not the cheapest case around (at £149.50), but it's well worth the money.
Now if only it came in colours... (hint, hint...)
Give us your thoughts on the modding or the case in general
in our forums.
Does look extremely snazzy though.
If you spend long enough working inside bad cases, good cases suddenly seem worth the £100-200 they cost. A well designed, easy to use, easy to keep neat, and expandable case - is worth good money, especially if one likes the look of it.
To be honest I think it spoils the look.
The legendary Coolermaster BlackWidow had a window on the outside so let's not hold that against KustomPCs. Now a £70 mark up can be held against them.
Then again, in my experience, "neat and clean" is relative in a P180.
Personally I think an almost 85% addition on the general retail price of the case alone is a little steep; but it's probably just me.
Thanks for your comments here - I've joined to address a few points raised...
'They couldn't fit it on the inside'
Correct - it's not possible to fit a window on the inside of the P180 case since the structure of the case is almost flush with the side panel. Besides, it wouldn't look so great, since the panel is thicker than most cases and would look a bit ugly to be exposde on the outside. We've been fitting windows on the 'inside' of cases for 6 years, so it would hardly be 'new' news.
Yes, what we've done does draw inspiration from the CoolerMaster cases, although using black rivets to complement the P180 scheme rather than screws.
There's a few concerns about price - yes, it is a lot more than the standard case (which we do continue to sell). The acrylic makes up the bulk of the price increase - it's not something we can buy 'off the shelf' and so the 5mm sheets of acrylic (thicker than the 2mm or 3mm used in most cases) have to be chamfered and polished especially for this modification, since just using a ragged sheet of acrylic would look absolutely awful. I appreciate I shouldn't hotlink images on this forum, but if you click the product link to our site in the article and see the close-up shot you'll appreciate that this acrylic looks far better than what's fitted on most stock cases.
Other than that, it's simply a question of volume - yes, CoolerMaster could produce a windowed case for maybe £20 more than their standard version, but they likely produced a couple of thousand of those at a time. Whereas, we might sell 10 of these over the course of a year. Resulting in higher acrylic price and of course that there's a lot of hand-work involved in actually producing this finished product.
We would love to sell hundreds of them and make it cheaper, but realistically it's unlikely to happen. But at least now anyone looking for a windowed P180 case has a choice that they didn't have before...
Felt it was only fair that I defended our corner a little and explained some of the 'how and why' on this.
Thanks,
Graeme
and for the gaming rig I felt it would be an interesting engineering project to see what could be done about fitting a window to it.
I threw out an exterior window as being too obtrusive and an interior one due to the fact that it wouldn't fit; so I decided to try a window flush with the exterior of the case.
the key to the project was the triple layer design of the panel. first I cut the window hole out neatly on a CNC machine I homebuilt out of old dot-matrix printers for a CAD/CAM project. once that was done I cut the plexiglas out slightly larger than the case window hole and had the CNC shave off some of the edge so the inner area was the same as the window.
then a couple of well placed drill holes in the corners with a beveled edge and some fan screws was all it took to finish.
I'm quite proud of it, my freind thought it was done by the original manufacturer!
only thing to think about now is some slots for the fan switches..
