FiveWood by cc3d
The (not-so-) little things
FiveWood by cc3d Details
One of the most noticeable features of FiveWood is its unique side panels, which are in fact doors that slide up on a track. The vortex-inspired look (Chris calls it the "swirlish") was carefully designed...
FiveWood by cc3d DetailsFiveWood by cc3d Details
Click to enlarge.
...and the individual pieces cut from the various woods. These were then stained and subsequently glued to the door's maple backing, which was covered in copper.
FiveWood by cc3d Details FiveWood by cc3d Details
Click to enlarge.
The feet were made from blocks constructed of layered mahogany, padauk, walnut and maple.
Click to enlarge.
Chris didn't skimp on crafting anything, including the power button and reset button. Though he did cheat a little - the fan grilles were cut from copper using a waterjet instead. This wasn't for lack of attempts, though - he tried making wooden ones, and even wooden fanblades. Then he decided he'd try actually finishing the project.
Click to enlarge.
All that was left to do with FiveWood was to stain it and assemble it. You can see what a difference the stain makes on the drive bays above, but that's only the start.
