The Reflection HTPC by Wolverine
The switches and final hardware
The Reflection HTPC by Wolverine Switches and final hardware
Now that I had the hardware all hooked up, I wanted to try it out so that I could do a full test of the system and fire up the LCD.
The Reflection HTPC by Wolverine Switches and final hardware The Reflection HTPC by Wolverine Switches and final hardware
The case was starting to look as I wanted it, but there were still I few things to do, like a power and reset switch. To fill that job, I choose chrome vandal resistant switches because these babies just fit the theme perfectly.
First off, I drilled a couple of holes. Then I filled the holes with the switches, hooked 'em up and Voila!
Now all that is left is the corners and to replace the old dead drives with a couple of fresh ones. So, lets do the drives first, shall we? The mock-ups were removed and replaced with two shining new 1TB Drives from Seagate.
With that done, there's just one thing left - the corners.
