The plastic front panel was removed and the disk flap and eject button covered with modellers aluminium plating foil. Next the Lian-Li drive plate was marked out using the drives original plastic front as a template. The slots were made by drilling a series of holes to remove most of the unwanted metal and then tidied up using needle files.
Fibre optic treatment is given.
The finished plate is push fitted onto the drive's chassis and here's how it looks accessing a disk.
That's all for now - until next time... Happy modding!
