Macro Case by macroman
Let's jump off the fan bus...
I have been ask many times "Where did you get those knobs from?". Well, they came from Maplin Electronics in the UK, part number YR65V and are 22mm in diameter.
Here is the finished unit in action...
Macro Case by macroman Finshing the Fanbus...
That’s about it. Where’s the LCD? You ask. Well, that’s currently undergoing modding surgery and will make its appearance when it is fully recovered.
Just for the record here’s how it looked before it went under the modder's Dremel. How it will look when it comes out is anybody's guess, so stay tuned to find out!
