Beyond the Grave by Edvuld
To top it all
Beyond the Grave by Edvuld Around the Bend...
I added a big cross to the top of the case, as well as a little something in two of the corners.
Beyond the Grave by Edvuld Around the Bend... Beyond the Grave by Edvuld Around the Bend...
The corner pieces will connect to the other sides which have resembling parts cut out in their corresponding corners.
Do you bend?
Once again, the joy of bending acrylic is upon us all.
I used a heat-gun and the wooden 90-degree supports to make the supporting system for the front I/O, as well as making a small support to hold the PSU in place.
