Front panel
The front panel was probably the hardest part of the case to design, given how simple the solution was born. I kept coming back to it over and over because the front is the tying element of the case and the area that makes the first impact.
In the end, I ended up going with a couple simple characters which mean “carpentry” in Japanese. They seemed fitting and they fit the aesthetics I was looking for.
To cut this design, I first drew it on the case to get the best placement. I then cut out a practice piece to see if I could do it well enough with my jig saw.
With proof of concept, I went ahead with the final piece. There was a lot of sanding in making this thing look good.
Yuugou by Greensabbath Front panel and wiring Yuugou by Greensabbath Front panel and wiring
Wiring
The wiring job in this case was a big deal for me. In Sangaku, I ended up doing a poor (ugly) job of wiring and I ended up redoing it once or twice and I didn’t want that to be the case this time. I also wanted to continue the theme of being proud to show off every (any) element of the case.
To do this, I decided to integrate the wiring scheme with the aluminium frame. To make this happen, I had to plan ahead. I did this by making a full scale mock up of the wiring out of tape and string.
To make this work, I would need a system of blocks that could be taking in and out and would hold the wires in place. I milled these out of the same aluminium stock as the rest of the main case supports.
I attached the blocks using 6-32 alloy steel button head cap screws, very nice. I also milled a nifty holder for the buttons for the case out of aluminium.
Shopping
