The rear PSU
The rear obviously has the same theme as the rest of the case, orange acrylic and brushed aluminum. Aluminum and orange flourescent acrylic has been cut, and mounted on the back of the case. I'm using a small SFF PSU from FSP for this project, mainly beacause this type of PSU is really small, but also because the components inside will be fairly small stuff. The PSU is rated at 350W.
I cut a rectangular hole in the back panels for the PSU to sqeeze through, and after that I milled a plate to mount the PSU on (for easy removal). It's made from 2mm aluminum. I also cut the acrylic to allow for expansion cards and motherboard ports. The motherboard itself is Micro-ATX, as you can see from the shot of the board.
The last thing on this project was to get the PSU sleeved. Needles do work great at removing connectors, although doing so takes a long, long time.
