I think all retail buttons are kinda ugly. And they certainly don't go with the theme in mind. Therefore the solution is obvious, make your own! I found some steel sockets, rings to use as a housing for the button, and after a while I figured out a practical, and good looking setup.
I milled a hole in the ring on the front, and fitted the button inside. Apart from the steel rings, I used a small spring and a rubbish old plastic power button from an old case as the actual mechanism. Works perfectly!
Some new sleeving and some solder later, and we're getting a little closer to completion.
