The aluminium panels
Hangar 101 by SleepStreamer The aluminium panels
Hangar 101 by SleepStreamer The aluminium panels Hangar 101 by SleepStreamer The aluminium panels Hangar 101 by SleepStreamer The aluminium panels Hangar 101 by SleepStreamer The aluminium panels Hangar 101 by SleepStreamer The aluminium panels Hangar 101 by SleepStreamer The aluminium panels
As I mentioned earlier, all the 3mm acrylic panels I had contemplated have been swapped for 3mm aluminium instead. For cutting it I use a simple jigsaw. The effects were pretty good, in the end.
Here you can see some further acrylic detailing in the top. The vents are also mounted to the side here. You can begin to see the design of the case come together, with the orange acrylic on top of the sleek metal. I think it looks sweet!
