The final case I've created is a sponsored mod for Abit. The board inside is a Fatal1ty AN9 32X, and so I thought it would be good to go with a bit of a Fatal1ty theme. I picked out the Zalman case and PSU that bear his name.
The case is made from 4mm aluminium sheets that look pretty easy to work with.
I decided to do a fancy paint job on the monitor, and this required some fairly comprehensive masking tape action!
I sanded down the finish on the aluminium case so that the primer would stick to it without any problems.
Here are some of the glory shots of the case - you can check out the full project log in the forums.
