Cold Fusion by SleepStreamer
Finishing the front
The plastic front of this case really needs some work - I'm planning to add some metal to it.
Cold Fusion by SleepStreamer Finishing the front Cold Fusion by SleepStreamer Finishing the front
The "geels", or vents in the front are neither nice, nor do the go with my theme, so I decided to lose them... I'm going to make a grill on the front using the perforated metal I bought earlier - I'm also going to make two side supports for the perforated grill using 1mm aluminium. On the left you can see the template I used, and the finished item.
I made pair of aluminium brackets to hold the logo. However, a problem has come up: with the brackets in place, I can't seem to fit the acrylic structures onto the front of the case, because the bolts that hold the grill are in the way. I ended up modifying the acrylic front a little to get it all to fit.
I added in some bent metal bars as an interesting stand-off for the front etched section.
Illuminating the front
I decided to add some lighting here as well. Two little fittings made from soft modelling plastic. The LEDs will be embedded inside these things.
After some fiddling with a soldering iron and some braided sleeving, the lighting was almost there - a case of routing the cables in the right place and drilling the hole to mount them.
