Cold Fusion by SleepStreamer
Detailing the side
Cold Fusion by SleepStreamer Detailing the side Cold Fusion by SleepStreamer Detailing the side
I grabbed an engraving tool to do some detailing around the side panel, scratching off the black paint and exposing the steel underneath for artistic effect.
To finish off the side, I needed to get the polish out, and this is where Autosol comes in - it's a car cleaner that works well on this kind of stainless steel. As you can see, the result is pretty nice!
With that done, I had to start pulling apart the case to progress with the rest of the mod.
