Cold Fusion by SleepStreamer
Finishing touches
Cold Fusion by SleepStreamer Finishing touches Cold Fusion by SleepStreamer Finishing touches
The first step is to pull off the existing rubber feet from the case - a job fairly easily done with the assistance of a craft knife.
These are the replacement metal feet. I had them laser cut, and have manually polished them up. I threaded them and drilled straight into the case itself to bolt them on. I really like the way the bolt is counter-sunk into the foot!
Here are the feet all done.
With that final job done, it was just a case of bringing all the pieces together, sticking in the hardware and then powering up for the first time. Turn the page to see the final result.
