Silent ContexYZ by Mr Kholl
Front bezel modding
I decided to make a change to the front bezel of the Cavalier case, both for aesthetic and cooling purposes.
Silent ContexYZ by Mr Kholl Front bezel Silent ContexYZ by Mr Kholl Front bezel
This was the design I came up with in Corel Draw, with the drilling markings.
I used my manual drill machine with two sizes of hole saw to make the cuts, using another die-cut vinyl mask as a guide.
I finished the holes off with a dremel to get them smooth.
I cut out a Cooler Master logo from a case badget and added it onto some aluminium mesh, which I have gone on to use throughout the project.
